When I bought my first Bridgeport it came with a ten inch Enco rotary table with a 12 X 18 X 1.5 inch Well used Al tooling plate attached. It is heavy and consequently it has not been used a lot. I had never seen and therefore never thought much about a smaller rotary table. I saw one recently that was about 6 inch. that looked like it would be very easy to use. A quick look in the Enco catalog shows a Phase two for a couple hundred Dollars. What size brand and quality are you using and what would your reccomendations be?
