Results 1 to 4 of 4
Thread: Help ID'ing boring? tool
    Default Help ID'ing boring? tool
    Hello,
    I found this at the scrap yard:
    I'm curious about what exactly it is, and if there's a chance I could use it with my 9" SB lathe. The shaft is 1.5" diameter. The cutters seem to be adjustable from about 3" to maybe 4" - I haven't taken it apart and cleaned the inside yet. The only visible marking is "Herbert" and looks like "BSAL". Might be from Herbert and Cridan in the UK as there is something similar on their site but pretty small and no other info I could find.
    Thanks,
    Gary Fuchs
    Aug 2005
    shreveport La
    Smile
    Looks like a counter bore tool. For a turret lathe.
    Sep 2006
    Southwestern Ontario, Canada
    It's a combination centering and facing tool that was used on a capstan lathes for mass production work.
    Picture from Model Engineer mag. Oct. 9, 1941
    Thank you both, looks like I won't be using it though.
    Gary
