I've got a leaky toilet which two new flappers have failed to fix..
The flush valve seat appears to be in good shape, i.e. there are no scratches or cuts that I can feel in the seating surface, but evidently it's worn enough so the surface is not flat or plane. (The house (and toilet) is 18 yrs old. The valve seat is some kind of plastic or PVC.)
My friend google found this fix made by Fluidmaster, which consists of a self-stick putty ring:
http://homerepair.about.com/od/plumb...et_flap555.htm
Have any of you used this, or something similar? ...or know of some other good solution?
Also, can someone tell me why, as I've gotten older and find fixing problems like this attended by less joy and excitement, they never have the easy solutions they used to have?![]()
And don't expect anything to make it through the "5 year warranty!" I keep a spare set in the house. It's all cheap stuff and about 2-3 years is the life I get. Too inexpensive to worry about saving receipts.
