Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Worm Gear pillage
    Default Worm Gear pillage
    Hello everyone
    I am thinking about making a rotary table. I was just wondering if anyone knew where I could find a good worm gear?
    Like I have said in a previous post I have been able to make an acceptable manual rotab, so I am thinking my next best bet would be to make another one but better.
    thanks all
    Jun 2008
    Yorkshire, Centre of the known Universe
    I'm chiming in before HE gets a chance, have you checked his holiness's site, division plates too.
    Regards Ian.
    You might not like what I say,but that doesn't mean I'm wrong.
    hello sir
    as you can tell by my post count that I am a newb and thusly am un aware of the site with which you speak.
    Jun 2008
    Sorry, the illustrious Sir John Stevenson, (Did I spell it all correctly John???)
    No connection whatsoever, just another dissilusioned fat chewer.
    Regards Ian.
    (PS. Look on the bottom of one of his postings for the site)
    May 2003
    52N 122W Western Kanuckistan
    They aren't hard to make. I have made quite a few including this one. This is 7075 alumimnum, slightly harder than steel. Bronze is a good choice and easy to machine although a bit expensive in the larger sizes. Steel works fine but requires a tool steel hob, not a big issue if you can harden it.
    Shown is the wheel and the hob used to cut it.
    L&S Industries sells grinding wheels Made In USA, all types and sizes. Also Superabrasive diamond and CBN wheels, no extra cost for custom wheels, Made in Canada. 10% discount for HSM members. Call Janet 250-392-3393 08:00-12:00, 13:00-15:00 M-F Pacific Paid Ad, updated Apr 01 2013
    update 2013/3/31 . Free software for calculating bolt circles and similar: Origin now settable to bottom left! All values positive. Click Here
    hello evan could you please make me one and send it to australia?
    Jun 2008
    You got mail Michael
  8. #8
    hello chaps
    was a good day,
    I got a reduction gear box to use as a guts to my rotab. I was thinking of building a box for it and arranging some kind of thrust bearing system for it.
    I was thinking that why don't I just make an adapter and bolt the chuck straight onto the output shaft, add a dial to the input shaft and bobs your aunty..
    does anyone know if this box could handle the loads placed on it when used beneath a milling machine to cut radii etc?
    Just putting it out there......
    Last edited by michael3fingers; 07-24-2009 at 08:26 AM. Reason: trying to turn on email notification
  9. #9
    May 2003
    Looks like a 6206 bearing on the input shaft and a larger deep groove bearing on the output. It looks pretty stout to me. It should work. The only concern is damage to the bearing from shock loads. Ball bearings have a much lower allowable static load than dynamic load. They are a lot easier to damage when they are not turning.
  10. #10
    thanks for the reply evan,,
    I was just looking at this picture here
    http://www.phase2plus.com/details.as..._TABLES#221304
    at it looks basically the same.... add a handle and away I go.
    as long as the output shaft has limited movement (side to side, in and out) I cant see it being any worse than a cheap import.. If problems arise I could always redesign parts of it.
