Results 1 to 10 of 10
Thread: Cole Drill revisited
Hybrid View
    Aug 2006
    West Sussex UK
    Default Cole Drill revisited
    Every so often I come across references to this tool. For the sort of work I do it would make a lot of sense. However the chances of me running across such a thing in the UK are miniscule so given the simple nature of the thing I've decided to have a bash at making my own. I think I've gathered most of the information I need from looking at photos but I'd like to sense check a few things with those who may have used the real thing.
    What I'd like to know:-
    How long is the hollow bolt that the drill spindle runs thru?
    Is there a thrust bearing used? And if so where is it, top or bottom of
    the hollow bolt?
    So far I am planning to use a M16x1.5mm bolt drilled to take the spindle and an off the shelf thrust bearing at the bottom of the bolt running against a flange on the drill spindle.
    For the ratchet drive best I can come up with at the moment is to use a 1/2" drive ratchet from a socket set which kind of leads to the logic of turning the drill spindle from an extension bar from a 1/2" set.
    If I can find some cast iron chunks I could use this for the body of the drill head and base but failing that there should be no problem using cut offs of mild steel, say 3"X2" ?
    Once again all information, ideas and suggestions gratefully received. If I get started with this I promise to take photos!
    Thanks
    Alan
    Mar 2008
    Vermont
    The hollow bolt is about two inches long. The spindle is stepped, with a smaller diameter through the hollow bolt, and the thrust bearing goes between the bottom of the hollow bolt and the wider portion of the spindle. I am guessing that this would be stronger than a flange. It's a simple ball thrust bearing similar to those found in scissor jacks and the like.
    If you need, I can take pictures and get proper dimensions later.
    Mar 2008
    Vermont
    Here's a quick shot of the spindle and screw assembly. The spindle below the bearing is 1 inch diameter, and about 1/2 inch where it goes through the screw.
    The ratchet is a simple spring-loaded plunger in the handle. One way only, no reverse. The ratchet wheel is threaded to the top of the spindle with a little shoulder, so when you turn the handle it simply tightens down on the shoulder.[IMG][/IMG]
    Aug 2006
    West Sussex UK
    Thanks Bruto, that's brilliant. Exactly the information I required. Very kind of you to take the trouble to do that.
    On a different tack, Vermont is one of the few states I've visited. My brother-in-law had a scholarship at Harvard back in the late eighties. My wife and I paid a brief visit one February which co-incided with one of the heaviest snowfalls that area had seen for a long time. Nevertheless we managed to get about OK and Vermont we decided was our favourite as it was most like home.
    Thanks for your help once again.
    Alan
    Aug 2006
    I purchased one from the US through Ebay, shipping was over $100 but it was
    well worth it they are a great tool.
    Previous to this purchase I intended to make one and have good diagrams
    with measurments etc.
    If you would like copies of these send your postal address via a personal message and I will mail them to you.
    Aug 2006
    West Sussex UK
    RW, that is very kind of you. My address is on it's way.
    Thank you
    Alan
