Results 1 to 10 of 25
Thread: 3 jaw chuck problems
    Sep 2008
    Merkel, Tx
    Default 3 jaw chuck problems
    Hi all,
    I am having problems with the accuracy of my three jaw chuck. The chuck came with the Lathe (Jet 1340) and is showing about .003 tir. I think this is about as good as it is going to get with this chuck. I am still working with my 4 jaw, but what a pain. I understand the adjustable 3 jaw chucks can be dialed in to .0005 tir. I am considering the one from Enco or possibly a Phase II. I think the Buck/Bison may be out of my price range.
    Has anybody had any experience with one of these chucks? Any recommendations will be welcome.
    Thanks,
    Tim
    Bremerton Washington
    Yeah working with a four jaw is a pain at first but if you need accuracy and gentle holding power that's the chuck you use.
    Three jaw chucks are delicate. One little wreck is all it takes to spring their jaws slightly and hamper their ability to hold work concentric and in parallel alignment with the spindle axis. Bust one parting tool in a three jaw and then inspect the accuracy of its grip. Bust a parting tool in an adjustable three jaw and you can correct for concentricity but the work may still stick out at an angle like a cow's ear. Concentric adjustment doesn't cure angularity.
    A four jaw is not rocket science but you have to practice with it. In a good shop an apprentice is not permitted to use any but a four jaw in his first rotation through the lathes. New guys absolutely positively HAVE to learn to efficiently use a four jaw chuck, not only as a rite of passage but because it's such a quick and effective work holder. Trust me, you will eventually come to think, "why the hell did I ever think a four jaw was a PITA?"
    Don't get me wrong. Three jaws chucks are irreplacible for some types of work. Three jaw chucks, four jaw chucks, collets, dead centers and driving dogs, face plates, spuds, pots, and so on are all but spindle tooling each with their advantages and range of purposes and a good lathe hands know which to use and when. Three jaw chucks are great for a noob's early experience but they are like training wheels. Sooner or later you will have to move on to other workholding systems to gain experience and efficiency. I use three jaw chucks often but I also use the four jaw. I'm changing chucks all the time. Sometimes I get lazy and use the three jaw when the four jaw is indicated but about half the time it's the other ways around.
    Here's something to shoot for: set up the four jaw and dial in a piece of cold roll to 0.001 in less than two minutes. I just went out to the shop and dialed in an old wrist pin to 0.0005" TIR taking 1:38 according to the stopwatch on my cell phone. I can still do it and I turned 68 acouple days ago. I was quicker back in the day but then I could leap tall buildings.
    Tim:
    You might check the specs for your lathe chuck, but .003" is probably about what one would expect for TIR on your chuck. If you really need better than that you seem to have already provided a solution: use your 4 jaw. With practice the 4 jaw may even become your preferred chuck. But....hold it...I still use a 3 jaw chuck that probably doesn't do much better than yours. What does it really matter if you have .003" or .0005" of TIR on your chuck? It doesn't make that much difference unless you are re chucking something or you have to chuck something that have been previously turned and must be concentric. In which case the 4 jaw is what I use. Even .0005" is still out. Why settle for that?
    Sep 2008
    Merkel, Tx
    Thanks fellas,
    I agree that in most cases that a 4 jaw is the way to go when accuracy is desired. I will continue to work with the 4 jaw and I am sure that I will get better with it. Part of my problem may be that I am chucking old 1" schedule 40 rigid conduit. It is probably not very round to begin with and I think I might be squishing it. I will go today and get an old wrist pin to practice with. Still, it just bugs me to see the work wobble in the chuck (on the 3 jaw) and know that it is as good as it gets with this chuck. I was reading in "Machine Shop Trade Secrets" the other night. The author said something to the effect of: Don't bother messing with a crappy three jaw chuck, get a good one to begin with. Hence my quest for an adjustable 3 jaw.
    Tim
    Sep 2004
    Oregon Coast
    I had read some where, maybe here, that you should check the accuracy of each of the three screws used to tighten the jaws. I know that my cheap Grizzly 3 jaw has it's most accurate screw. Give it a try.
    Mel
    Mel Larsen
    Remember when your cup holder sat next to you and wore a poodle skirt?
    Palmer Alaska
    Default Lets see...
    Take a 3 jaw...
    Put 4 adjustment screws on it ala Adjust Tru..
    Tighten 3 jaw, adjust 4 screws... Will get you close for multiple same size work, but if it needs to be tighter than say .001, you still have to deal with adjustment screws.. And thats only if your workpiece is clean, round, and concentric..
    Manual 4 jaw is faster for manual tight tolerance work, why bother?
    Variable clamping pressure of a 4 jaw comes in handy, if you have a single thin area to clamp on...
    Collets are fast and accurate.
    Centers and Lathe Dogs work fine for work that can be supported that way..
    My three jaw gets mounted maybe 2 times a year. Sometimes I can live with .006 to .060 or so runout... on simple spacers and such, and working to more accuracy than needed, is just a waste of time....
    My 3 jaw is like new so it probably is still under .004 or so... Never do tight work with it, so have never measured runout with a ground wristpin...
    Oct 2007
    I've come to understand 3-jaw chucks are for production type work.
    1. Inhale oversized stock.
    2. Face/size/[drill]/[bore]/[ream]/[thread]/part
    3. GOTO 1
    If you need to re-chuck then 4-jaw, collets, centers-and-dogs, or faceplates are in order.
    My experience with tubing in 3-jaw chucks consists mostly of jumping, ducking, and going back in the house both more learned and muttering...
    Feb 2008
    Arizona
    My three jaw is out at least .003 I use paper under the jaws to rough center the material. I can get "really close" to center with that method. A couple of pieces of .003 paper will normally work.
    I use a 4 jaw to do repeat jobs.
    Maine
    4-jaws get easier/faster with practice. I find it helps to think of it almost as a pair of 2-jaw chucks, 90 degrees apart. Concentrate on getting the stock correct with respect to jaws 1-3 first, then get it correct with respect to 2-4. (Then go back and verify 1-3, of course, and make small adjustments). You'll need to leave 1-3 loose enough so you can still move the work as required with 2-4, and "loose enough" (but not too loose) is one of those things that comes with practice.
    Feb 2009
    New Joisey
    A 3 jaw is fine..but if I have a choice and the part must be concentric to .001 or so, give me a 4 jaw anytime. Even with repeat work the same size it takes an amazingly small amount of time to re-indicate the new part. Just loosen the same 2 jaws and tighten the same two jaws in reverse sequence when you put the new part in to be turned (last loosened, first tightened). When you learn thru repetition the amount of force to put on the chuck wrench to center the part you will find the part is out only ten or so thousandths at worst...often much less.
