I am trying to remember the name of some red insulating board we used to use at a plant I worked at. And once someone can help me with a name, can someone point me to a place to get some small scraps.
thanks.
thanks.
google "micarta"
Gene
that's it. Anyone have any scraps to sell ?
How much? What size/thickness? Does it have to be red?Originally Posted by Bmyers
1/2" square, about 6" long. doesnt have to be red
I've got these two pieces:
Up close:
I can get the actual dimensions if you're interested. I may have some other odd-shaped pieces, too.
Roger
Roger,
PM sent
Not the same stuff...
You may want the bright red "GPO-3" insulating board, which is NOT the linen-phenolic "micarta" as per the picture, but a glass-epoxy material rated UL 94V-0. That material can be used in direct contact with voltage/opposite polarity, etc.
You can get it in 12 x 12 inch sheets of varying thickness at MSC and also at McMaster-Carr, IIRC.
