Machinists,
My brothers have several steel pieces that have a pin welded through a hole. The pins are worn from years of rubbing on a bushing. The new parts are $70 each and I need 24 of them (yep, it's the planter again). I was wondering if an annular cutter on a slow speed drill press would cut the weld so the pin can be removed and replaced. The weld is on a 1" dia pin. The pin is proud of the arm and not plug welded, just welded on the OD. This would cut the weld off with minimal grinding. I've use annular cutters quite a bit, but never on a weld.
I thought grinding would be cheapest, but take forever. They don't have a milling machine handy and I'm too far away to do any good.
Any other ideas are greatly appreciated.
Regards,
Jimno
