Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: My new milling machine
    Beaverton, OR
    Default My new milling machine
    OK, Not the kind of mill you are thinking but I can remove nanometers at a time with this one!
    Its an old Focused Ion Beam (FIB) Milling machine. Mostly got it for the vacuum system. Has a 6" Diffusion pump with trap and all the plumbing to go with it. Also Dual thermocouple gauges and an ion gauge.
    Jul 2009
    SF bay area, CA
    For making really really small parts.
    South Wales
    okay so you are building a doomsday device, do we get the heads up before the end?
    mark
    Aug 2008
    Missouri, USA
    Quote Originally Posted by beanbag
    Or tattoos....
    http://en.wikipedia.org/wiki/File:Mc...hair_tatoo.JPG
    Dec 2008
    N.E. oHIo
    Cool unit!
    I figure nano-chips are a lot less messy at clean up time.
    Rex
    May 2005
    UK
    So where does the workpiece go?
    Tim
    Jun 2004
    Austin,TX
    Wow, you could do micro-engraving!
    Wow can it tell the lottery numbers? NO.I thought not.Please keep working on it till it does then I'll buy one Alistair
    Beaverton, OR
    Quote Originally Posted by Timleech
    Tim
    It goes in the center of the chamber on a small mount. Maybe 3/8" in diameter. Has a small gear motor that allows you to spin the part as well. Ion Lathe???
    Its an old machine, probably one of the earlier commercial machines I am guessing. I have not seen a date anywhere on it yet.
    Wiki has a little about these machines, but it applies more to the newer machines than this one. I got it as a vacuum source to do neon and plasma stuff.
    http://en.wikipedia.org/wiki/Focused_ion_beam
    Jul 2005
    Bloomington, IN
    Hey Macona ... if you need any vacuum goodies - flanges, etc - you might drop me a pm. I might be able to scrounge up some surplus stuff and pay you back for the feedthrough you sent me...
