Common Codes
G-codes are also called preparatory codes, and are any word in a CNC program that begins with the letter 'G'. Generally it is a code telling the machine tool what type of action to perform, such as:
rapid move
controlled feed move in a straight line or arc
series of controlled feed moves that would result in a hole being bored, a workpiece cut (routed) to a specific dimension, or a decorative profile shape added to the edge of a workpiece.
change a pallet
set tool information such as offset.
There are other codes; the type codes can be thought of like registers in a computer
X absolute position
Y absolute position
Z absolute position
A position (rotary around X)
B position (rotary around Y)
C position (rotary around Z)
U Relative axis parallel to X
V Relative axis parallel to Y
W Relative axis parallel to Z
