Picked up a NEF SB2 used. Someone must have done a trigger job on it.
(Did a good job of it) BUT when it was reassembled the two top front pins were switched. I used two 3'16" tool steel pins to drift them out. In the process of switching the pins back to there correct locations I LOST the lifter spring off the pin. Any good ideas as to getting this spring back in correctly?
