Results 1 to 10 of 14
Thread: Pipe threading on a lathe
    Jan 2008
    Mouldy, Or
    Default Pipe threading on a lathe
    Perhaps a known trick but as I (re)discovered it, I will pass it along
    threading pipe on a lathe is complicated by the fact the thread is on a cone
    with a 1 deg 47 minute taper, the options I read about were:
    1) Don't. Use a pipe threader, that is what they are for.
    2) offset tail stock and turn between centers
    3) back the cross slide off a certain number of thou per revolution
    well, my part is not a pipe and won't fit in the pipe threader
    I could turn between off set centers but it is a fiddley setup to get a dog on
    a short piece and then would have to set the taper up properly
    and restore the tailstock to center when done
    manually backing the cross slide off on the fly
    when there are already plenty of things to keep track of
    while threading a short section seems like inviting a problem
    especially if there are a number to do.
    the way I found was to use a jaw from the pipe threading tool
    as a form tool just as you would single point an untapered thread of the same pitch.
    Clamp the tool parallel with the face of the chuck
    and back it off & disengage the feed (in that order)
    when it just becomes fully engaged.
    Tom C
    ... nice weather eh?
    Dec 2003
    Palo Alto, California
    Good going, schmarty! I have a pipe threading die set, and I'll try to remember this trick, you betcha.
    Frank Ford
    HomeShopTech
    Beaverton, OR
    You missed the fourth option. Use a lathe with a taper attachment.
    Your technique here also works using taps as the cutting tool to cut the thread.
    Jul 2009
    Granite Falls, Washington
    Nice.
    I have a use for that TODAY
    Toledo, Ohio
    Good use of a threading die.
    While pipe threads are tapered, the stock is straight. Using the setover tailstock method will not produce the proper thread form. A taper attachment is about the only method of single pointing pipe thread. Backing off the compound will sort of work, but is a pretty iffy method unless leakage is not a problem.
    Sep 2004
    Default Good Application of Brain matter Buddy
    I do all types of wacky threads and this pipe thread tip is going to become one of my No Pain No Brain setups. thanx for the idea.
    NL
    "Your technique here also works using taps as the cutting tool to cut the thread."
    ? going to try it in the am as I have 6 1.250 pipe to do
    for the son's girl friend's father...
    please visit my webpage:
    http://motorworks88.webs.com/
    Toledo, Ohio
    Quote Originally Posted by motorworks
    That could be made to work with a bottoming tap for screw threads, but I would not be too sure about the applicability for pipe thread unless the tap is used the wrong way around. With pipe thread, the thread on the tap gets shallower the deeper the tap goes in. You would need to do some creative fixturing and grinding of the tap to get it to work if it would work at all.
    Apr 2009
    Columbus Texas
    I was going to post a topic on the same thing. We changed out the die teeth on our Ridged 300. Will any die number work?
    Feb 2007
    The tap would have a right hand thread,but would be presenting the thread at backwards of its angle to the pipe being threaded. Maybe if you presented the tap so the cutting edge was presented very much downhill to the pipe,you could avoid most of the conflicting thread angle issue.
    An old book I read described how you could make a left hand tap by trapping a rt. hand tap in a steel hole,and screwing a blank tap in beside it,which would come out left hand.
