Results 1 to 10 of 35
Thread: Homemade small press brake ?
    Jun 2005
    Victoria, Australia
    Default Homemade small press brake ?
    Has anybody made a small press brake the sort one would use for bending small parts to make brackets and like ?
    Something like I found on ebay.
    http://cgi.ebay.com/ebaymotors/18in-...motiveQ5fTools
    Jul 2007
    Central Oilberta
    Personally, no. It's on my round tuit list though. I've seen shop made pressbrakes up to +/- 60". Most dedicated press brakes start off with a H frame press http://www.mad4wd.com/gallery2/main.php?g2_itemId=463 . The largest had 4 - 3" x 12" hydraulic cylinders on a massive upper die. http://www.montgomeryauctions.com/up...3/P1010162.jpg
    Shop outfitters has one on their site http://www.shopoutfitters.com/Catalo...roducts_id=194 that should be easy to reverse engineer, but I can't for the life of me figger out how they think it's worth $689 ?!?
    I tried to find some pictures of the brake I saw that used 1/4" thick angle for both sides of the brake, but the pics have been removed from the photobucket account. The anvil side was made of two angle sections back to back with a spacer between. The maker reported it worked well for thin materials.
    I've toyed with the possibilities of a lower die made using parallel pieces of round stock spaced apart by 1/4" or so, but haven't done the experiments yet.
    Mar 2004
    Denmark
    Hi TR
    I have constructed and build a miniature bench brake like this :
    Jul 2009
    Merkel, Tx
    I priced a few - then made this:
    with a 6" bench vice and scrap angle iron, steel, clamps, some 2x4s and a rubber mallet.
    Jul 2007
    Central Oilberta
    Mogens
    Do you have plans for the bench brake? I'd like to build one for flashing in addition to the pressbrake for up to 1/4" or 3/8".
    Cam
    Sep 2006
    Southwestern Ontario, Canada
    I built a highly modified version of the Gingery brake, it works well, worth the cost of the book.
    Apr 2009
    Rock Island, Illinois
    Here are a couple that I have made.
    This one is for use in a hydraulic press.
    This one is portable. I built it around a H.F 12 ton air/hydraulic bottle jack.
    http://www.youtube.com/watch?v=B9u3QcLdAAE
    Plans in pdf format.
    http://www.mediafire.com/file/zyiti2mzqly/press brake prints.pdf
    This site has alot of different bending die measurements. Click the products tab on the left side of the screen.
    http://www.midwestpressbrake.com/index2.htm
    YES, I'M GRUMPY ALL THE TIME!
    DEAL WITH IT!
    Oct 2004
    Prestatyn, North-Wales
    be back with a pic
    i didnt make this one ..but it has more balls that the ebay item and was 1/15th of the price when bought a couple of years ago. 20 new
    please dont phone jill up ...no connection ..just a run over mag sign, i found on the roadside.
    io think i win the award for the messy workbench handsdown ..
    the arms are 20mm in diametre
    all the best.markj
    Mar 2004
    SE, Michigan
    I'd like plans for Falcon's press if he has them. I'd imagine tolerances are +/- .001"?
    :-) That's my method as well. BFH! And if that doesn't work, you get a B'erFH
    Aug 2003
    Default Brake
    Check out my small sheet metal brake as shown in the "Home Metal Shop Club". Full plans are available on the site in a zip format.
    JRW
