Results 1 to 10 of 12
Thread: 4 jaw self centering chucks
    Dec 2006
    Suffolk, UK
    Default 4 jaw self centering chucks
    In the 1960s I purchased a Rohm (German) 4 jaw self centering chuck and over the years have found this so convenient as it will accurately hold both square and round stock, why are these 4 jaw chucks so scarce as to me they are so much better? Don't know if they are still available, I don't think the extra jaw would put the price out of bounds.
    This chuck of mine has been in constant use and still runs to a couple of thou. if I were starting a home shop again I would definately invest in another. David
    Jul 2008
    Dave,
    Bison makes them as do a lot of other manufacturers, Agree about how usefull they are.
    Pete
    Nov 2008
    Stavanger, Norway
    Dec 2006
    Suffolk, UK
    So other than price why would anyone buy a three jaw in preferance to a four jaw ? David
    airsmith282 Guest
    Quote Originally Posted by David S Newman
    my lathe came with a 3 jaw and i like it but i now have to have a 4 jaw do to the stuff ill be getting into next but it is possible to hold square in a 3 jaw but a 4 jaw is the best to use self centering is ideal if you need dead on center but other wise independent is the better way to go so i have been told so ill be getting both and use the one i need first the most and then use the other as needed,
    Dec 2006
    Suffolk, UK
    Quote Originally Posted by airsmith282
    Really don't see how you could hold square stock in a three jaw chuck to run concentric ?? Dvid
    Feb 2008
    Make a split bush with an ID of across corners measurement of stock.
    Re 4 jaw and round bar ;- it's the milking stool principle, not all 4J self centering chucks close that accurately
    Nov 2008
    Stavanger, Norway
    It seems to me that a worn or badly made 3 jaw SCC will always hold on all 3 jaws. But a 4 jaw SCC of the same condition might not hold on all 4 jaws. It's the 3 leg table versus 4 legs principle.
    If this is correct then buying a cheap 4 jaw SCC might not be such a good idea.
    Just a thought
    Phil
    Apr 2006
    Banbury England
    To hold Hexagon?
    Steve Larner
    Nov 2003
    Vancouver, WA
    Other then real small hex stock a 4 jaw self centering chuck will hold hex stock centered.
