Results 1 to 6 of 6
Thread: cuttermaster T&C grinder
    Jul 2009
    Certral Coast NSW OZ
    Default cuttermaster T&C grinder
    I just won a Falcon T&C grinder on ebay which is a copy of a Cuttermaster
    now its a little rough and a bit of a doer upper The major problem is with the air spindle can any one tell me what the clearance/tolerances are between the spindle and sleeve ?
    Jun 2008
    SF bay area, California, USA
    How fine are the clearences?
    "Pretty expletiveing small!"
    about 0.0005 inch.
    Aug 2004
    Central Queensland, Australia
    Quote Originally Posted by Teenage_Machinist
    about 0.0005 inch.
    I would disagree, being an air spindle clearances would need to be larger then you think to allow the air to rush out and centre the spindle..
    Jul 2009
    Now this is a dead ringer of the grinder I got for AU $382
    http://bbs.homeshopmachinist.net/sho...t=25540&page=2
    Nov 1999
    SE OZ
    Default Quill etc. info
    Quote Originally Posted by Ozcad
    Ozcad.
    my air-quill fit is so close that I have to very very careful as to how I insert it into the body of the quill-holder. It is easy to jamb it if I am not careful. A coat of "3-in-1" (sewing machine oil) if too heavy will make hard work of it. Just a very light wipe will do. The quill has a first class ground finish and the quill-holder bore is lapped.
    It is very smooth with no air applied but when the air is applied the quill will slide quick-smart on a grade/slope of not more than about 1/8" per foot (say 1:96 or 1"100 ~ 0.57 degrees) so I have to be careful that is does not get up enough speed to slide right out and head for the floor!!
    But to answer your question, I have not measured the clearance but my guess is that it is in the order of the low "tenths of an inch".
    My grinder came with metric 5C collets, but I never use them as I bought a "John Stevenson design" 5C>ER-32 adaptor and use my metric ER-32 collets instead as they will handle all diameters - inch and metric - from 2mm (~0.080") to 20mm (~0.800").
    Make yourself an adaptor like a common lathe tool-post with a parallel shank for your biggest collet:
    and get a "Spindexer" (top of pic):
    and you can grind any lathe tool with no need - or expense - for a modified (USA "Baldor") or similar modified pedestal grinder:
    https://www.machineryhouse.com.au/Se...mageField.y=12
    http://i200.photobucket.com/albums/a...lt_sander1.jpg
    http://i200.photobucket.com/albums/a...lt_sander2.jpg
    http://i200.photobucket.com/albums/a...lt_sander3.jpg
    Jul 2009
    Thanks oldtiffie for the detailed info I think I will try and get a local motor recon shop to bore and sleeve the quill holder then hone it should be able to get within .0002" or .0003"and I'll lap it in from there I can see I will be spending plenty of time making attachments
