This is mostly a mental excercise; I scratched out a drawing for a jig to generate involute gear tooth profiles for wooden gears (I am aware of Matthias Wandel's stuff on woodgears.ca; but I don't like scroll-sawing out gears). The design would require what appears to be a non-existent router bit with a profile of a rack tooth. An alternative would be to use a #1 involute cutter mill, and to adapt it to cut wood. Given that the cutting edges are all wrong for working in wood, what cutter life and quality of 'finish' would I get working in something like baltic birch plywood?
