Results 11 to 20 of 32
Thread: Using Unimat SL as a tool post grinder
    Stevens Point, WI
    Awesome! Because of the smaller size it looks as those the unimat is easier to mount in different positions than the 6" atlas would be. I'll have o start looking for a complete unimat headstock now I guess.
    Thanks for the pics Paul!!
    Beaumont, TX
    It's not only the smaller size, but also the fact that it is designed to rotate 360 degrees on it's mounting pin. The drilling or milling jobs I have shown could have easily been at an angle to the lathe axis.
    Stevens Point, WI
    When I originally thought about getting a lathe head I looked into the unimat and even watched a few auctions on ebay. But than I found some measurements of the unimat and thought it would be to small to handle endmills and small cutters and whatnot. So than I started watching for a 6" atlas. But after the pics you posted and the info I am glad I didn't get the atlas yet.
    Now the unimat prices are going to go up because of you.
    Jan 2008
    Mouldy, Or
    Default Yautp
    unfortunately going to school takes away details ... not unlike sandblasting your brain . so I apologize for not remembering the name of who on this forum I blatantly stole this idea from.
    base mounted in the toolpost
    base mounted in place of the compound
    at some point I expect I will make another mount point off the edge of the disk but I haven't needed it yet.
    edit. it is on a 10x24 Logan in this case
    Tom C
    ... nice weather eh?
    Jun 2008
    Instead of screwing up a perfectly good lathe, why not try this:-
    http://www.hemingwaykits.com/acatalo...ep_Mill__.html
    "Model Engineers Workshop" did a couple of constructional articles on the quickstep, so as the Chinese copyists haven't brought one out yet for everyone to have a tool gloat about being so cheap, you could try making your own.
    Alternatively, you could always mount a Sheerline on you toolpost.
    Regards Ian.
  6. #16
    Palmer Alaska
    Thats the beauty of the Unimat..
    For 645 UK Pounds (~ $1031.00) for that quick step mill, or the time needed to make it...
    I could buy a old Bridgeport Mill.... (don't need 2 tho...)
    Or buy 3 or 4 Unimats...
    No modifications needed at all to it...
    It is already designed for light milling and flexibility.
    Especially flexibility
    With care, it will do decent light work...
    A couple adapters for Compound slot and done ...
    I have most of the attachments, and will sharpen some end mills on it, when I get a couple more dull ones..
  7. #17
    Stevens Point, WI
    it is cheaper to get a unimat than to build a head, shaft, pulleys, and buy a motor.
  8. #18
    Jun 2008
    But a Sheerline would be MUCH better suited and accurate for bolting to the toolpost. Heck, you could even CNC it.
    Regards Ian.
  9. #19
    Nov 1999
    SE OZ
    Default The irony of it all
    I loved it - I just could not help myself!!!
    Using the "Unimat" on a lathe - a very good idea by the way - is turning (sorry) a USA-made "good old American iron" lathe into a dreaded "3-in-1" and so apparently cloning or "knocking off" an Asian (read: Chinese) product - "puny round-column mill" and all.
    And all with the approval of the "good old American iron" Brigade.
    I can see the iron(??) of it all.
    This has truly made my day (New Year's Eve) and my year (2009 going into 2010).
    It doesn't get better than this.
  10. #20
    Jun 2008
    Thanks Tiffe, a "Pat" on the head.
