I purchased an X3 mill from Grizzly, and the table is within .003 end-to-end (actually .0027, best as I can tell). Spec from Griz is .002, so they are saying "send it back." What a huge hassle, and loss of cleanup time that would be.
Unfortunately there is a diagonal .001 dip or arc across the table, about 1" wide, as if it's where a polishing machine spun down or something. (If it weren't for that, I'd be at under .002 all the way across.)
Is there any way I can improve flatness of the table, without the heroics of packing up the machine? Here are some options I'm considering:
I have a 9 x 12 grade B stone, flat at .0001 across the surface, can I mount sand paper to it and move it across the table, spending more time on the high areas, and stopping to measure progress every once in awhile?
I have heard of lapping on float glass. I have aluminum oxide powder of various grits from another project. Is that a possiblity?
What does one do in this situation?
