Results 1 to 10 of 29
Thread: Bandsaw coolant, home made, what do you use?
    Stevens Point, WI
    Default Bandsaw coolant, home made, what do you use?
    I have tried a few different things for coolant in my bandsaw. First I tryed watered down blue windseild washer fluid, it worked great but made the saw rusty. Than I tried mixing a little oil with it and it cooled well yet but didn't seam like enought to keep the saw from getting rusty. Lastly I tried strait ATF fluid which worked great for not making rust but it is to much lubricant and makes the blade slip on the wheel.
    I know you can buy a coolant but I hear a couple different stories of it being expensive and it will start to stink after awhile.
    So what do you guys use for coolant? Any good working home made suff that doesn't start to stink, doesn't make the saw rust, and doesn't make the saw slip?
    I just never used the coolant because I was cutting small stuff or tubing which never had the need for coolant. But lately I have been cutting bigger and bigger stock and more repetitively and it would be nice to be able to use coolant if the need arises.
    Nov 2009
    Oak Ridge Tenessee
    Default home made coolant
    Here is a recipe for some home made coolant. At a cost of around 50 cents a gallon
    1 quart cheep motor oil
    3 cups liquid dish washing soap
    4 gallons water
    The water acts as a coolant and the oil acts as a rust preventative
    Adding the soap will allow the oil to mix with water
    If you get a sticky residue on your machine you have to much soap.
    If mixed just right you will get a thin layer of oil on your machine and tools after the water evaporates.
    __________________
    Jan 2006
    Suffolk, England
    Quote Originally Posted by Machinist-Guide
    4 gallons water
    __________________
    Bad idea IMO.
    Most dish washing soaps contain salt in some proportion, so you're just adding to the corrosion potential.
    Nov 2009
    Machinist-guide... how do you use this solution? spray on? dripped on?
    Corvallis,Oregon
    Default Soft knurling on ring roller
    The knurling wore smothe on my ring roller after only running a few 1" hot roll pices through.
    Is there a way to harden the roller after reknurling it?
    Steve
    Nov 2009
    Oak Ridge Tenessee
    Default spray
    Quote Originally Posted by wagnerite
    I use it in a spray bottle. It separates pretty fast so I don't use it in a coolant tank.
    And if you use the lemon scent soap your shop will smell nice and lemony fresh.
    If you use it in a coolant tank with a pump it will be ok. After it sits over night it will separate and you will need to mix it
    Nov 2009
    Oak Ridge Tenessee
    Default case harden
    Quote Originally Posted by steve herman
    Steve
    Steve search the forum for case harden this may be your best bet. There are post on this subject that can help.
    Jul 2007
    No Cal.
    5 gal of Rustlix = $100
    Rustlix mixed 1:15 with Water = 75 gal / $1.33 per gal
    not worth rusting out your tools
    Rustlix is a synthetic so it doesn't go rancid. A 5 Gal bucket last about 18 months around here being run in all my tools.
    Dec 2008
    Luton,UK
    My friend Bob (Humbernut) is using Biocool 14 (from www.hallettoil.co.uk) and reports that it has lasted at least two years with intermittent use. I think that many of the synthetic coolants that form a translucent (usually green) working fluid will keep for a long time.
    Going 'bad' is associated with anerobic bacteria, so making sure the surface isn't covered with tramp oil is a good idea. If you're leaving machines idke for long periods, then consider an aquarium air pump on a timer.
    Canada, Bc
    What exactly is 'tramp' oil anyway?
    I really would'nt bother making your own.. I use pure rapidtap dribbled on everything and I barly use more then a few drops per job and the job gets totaly coated.
    You don't even really need coolant for your bandsaw unless your doing super thick peices or you want every last ounce of blade life, and even then you can just dribble some rapidtap or similar into the cut every 20 seconds.
