Results 1 to 10 of 11
Thread: Acme tap drill chart
    Northern KY.
    Default Acme tap drill chart
    I've searched for a Acme tap drill size and found no info for it. The size is 1/2 -10 LH Acme. I have my cross feed nut blank in the mill vise ready to drill as soon as I come up with the drill size. Anybody ?
    Paul
    Mar 2002
    webster, ma
    I just did the same nut (1/2x 10 acme.) Used a tandem tap from MSC. I drilled large enough to barely clear the end of the tap. The operation was very smooth. No problems as all.
    gvasale
    Nottingham, England
    First result from googling "acme tapping chart"
    http://www.victornet.com/reference/Acme_Tap_Drill.html
    Jan 2006
    Suffolk, England
    I can't categorically help with the correct tapping dill size, but I can point you in the direction of a very useful chart.
    http://www.landisthreadingsystems.co...hreadforms.pdf
    This gives you the option of several sizes for the major/minor diameters of the Acme thread depending on the tolerance class and fit you want.
    However as it's a nut for a leadscrew I would perhaps suggest that drilling undersize and then boring it to a more precise size commensurate with the fit you want to obtain may be a good idea.
    I've never tapped an Acme thread before (never screwcut one either that I can remember), but I suspect that others that have done so on here will provide you with better advice.
    Peter
    Northern KY.
    Thank's fellows, i don't understand why I didn't come up with a chart, John, it is embarrassing to see how quick you came up with it.
    Thank's again fellows. HSM comes to the rescue !!
    Paul
    Nov 2009
    Oak Ridge Tenessee
    Default Welcome neighbor
    I don't have a acme chart here at home. I just wanted to say welcome to the forum. I noticed you are from Ky' I am in TN. Hello neighbor!
    Western New York U.$.A
    pwasbury, note that on the website John Steveson posted it says that it's 10.4mm APROXIMATE What the hells with that John?; I thought that metric crap was so much more precise !!
    Dec 2006
    Hazel Park, Michigan
    Quote Originally Posted by Your Old Dog
    Nov 1999
    SE OZ
    Default Azzit tizz
    Hey YOD.
    Just how and where did you measure all those metric craps? I trust you were very PC. I guess you had your hands full.
    As you like it - or not
    Nottingham, England
    That's because it was measured with this
