I've seen a lot of shop made hammers over the years. That's one of the best looking ones yet. BTW - welcome to the Forum!![]()
Very nice knurling job on that handle.
...lew...
Nice! The end of the handle looks like it is a separate piece, is the handle hollow with a threaded cap so you can keep a punch or something similar in it?Originally Posted by H380
Pete
Thanks. I decided it was time to learn machine work. So I am taking classes at the local VoTech. The hammer was the last project in the basic lathe class.
Yep the handle is drilled and internal cut threaded 7/8 14. I need to scrounge up some brass to make a spacer between the cap and handle.
The handle is hollow so I would cuss when trying to cut threads with a self ground HSS tool in a self made 1/2" bar in a 7/8" hole.![]()
Thats one good looking hammer ..... Nicely done
If you are using violence and it does not work, You are not using enough.
I'd want Gasoline Per Hour. No Pee Pee for me.Originally Posted by steverice
Really Nice! How is the handle attached to the head? Press fit?
my bad, typo - should beOriginally Posted by GKman
pph: pounds per hour
gpm: gallons per minute
"the ocean is the ultimate solution"
It is threaded. I turned the head in a lathe. Then put it in an indexer on a mill. Milled the flats on the head. Locked the X and Y. Used the quill and a 3/4" end mill to cut the counter bore. Put in a drill chuck and center drilled, pilot and tap drilled. Then put the mill in neutral power off and put a tapered tap in the drill chuck. Start the tap in the hole by turning the chuck by hand and/or a strap wrench. Once the tap is started straight loosen the chuck and leave the tap in the hole. Turn away with a tap wrench. Then go to a plug tap and finish with a bottoming tap.Originally Posted by biometrics
I would just chucked it up in the vice and ran it in till the tap quit turning...but I am a hack.
