Page 68 of 195 FirstFirst ... 1858666768697078118168 ... LastLast
Results 671 to 680 of 1946
Thread: Shop Made Tools
  1. #671
    Nov 1999
    SE OZ
    Default Cost vs need vs value
    Originally Posted by kyfho
    For those of us that haven't acquired a surface plate yet, how flat/accurate could one expect a polished marble tile to be? 12" or 18" square, fairly common at Home DepoLowes.
    Quote Originally Posted by DICKEYBIRD
    Why not get the real thing?
    http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INLMK3
    Should be able to find a free shipping code. I got mine from Enco with free shipping a while back and it's great. Can't beat the price.
    Thanks DB.
    I went to the catalogue page at:
    http://www.use-enco.com/CGI/INPDFF?P...MITEM=640-0120
    and damn soon book-marked it and printed it out.
    That has to be the best summary of surface plate accuracy and sizes and slip guage accuracy etc. that I've seen to date.
    I have a chart/map/plot/non-NIST certificate with my surface plate and it's fine.
    People really should aim for the price for the size and quality they really need as if they down-grade unnecessarily for an unwarranted low price they may well come to regret it.
  2. #672
    Apr 2005
    Default Free shipping codes or not
    You guys don't know how lucky you are! I can't use a free shipping code 'cos they don't do free transatlantic shipping. I make do with a slab of hard polished limestone. I keep my eyes peeled on eBay hoping to pick up a reasonable surface plate locally. Here in France, second hand machines, tools, tooling etc are expensive. I imported my shaper, lathe clarkson T&G and my very beautiful Denbigh pillar drill (camel back) from the UK! So some of us can't easilly get the "real thing", alternatives are interesting to some!
    Regards, Matthew
  3. #673
    Canada, Bc
    try looking at tool stores to buy one new.. awhile ago I picked one up new at busybee for $60 iirc.
  4. #674
    Apr 2004
    Collierville, TN
    Quote Originally Posted by mattinker
    I hear you Matt. I do indeed realize and appreciate the bargains available to us here in the US.
    Careful research and patiently waiting (man that's hard!) for special deals has enabled me to equip my shop with far more goodies than I ever thought possible when I first got into the machining hobby.
    I got a feeling it won't last forever though.
  5. #675
    Mar 2008
    Kent, U.K.
    Tiffie I have one of those surface gauges and although I pretty-much knew what it was I wondered how exactly it's used? I also wonder what are the four sliding pins in the base for?
  6. #676
    Montana
    Pete
    I think the pins are used to follow a edge. Just push down and hang over the edge and trace.
    Hal
  7. #677
    Mar 2008
    Kent, U.K.
    Thanks Hal - that's what I figured.
  8. #678
    Nov 1999
    SE OZ
    Default Surface guage etc.
    Quote Originally Posted by Peter.
    Peter.
    I rarely use my digital height guage as I can do just about everything with my surface guage. It has a very good fine-feed tilting mast and can get into just about anywhere. I have a range of mast lengths = 8mm silver steel (01) that I make up as required. Same for the scriber = 4mm (need to check) SS/O1
    In a previous pic, notice how the mast of the 600mm digital height guage fouls the milling head - which is fully up - on my HF-45 mill.
    The pins on the SG are use to track along an edge - handy but not used all that often.
    The SG is cheap, hardy/durable, accurate and needs no batteries.
    I bought it from:
    http://littlemachineshop.com/product...3069&category=
    I can put my surface and height guages as well as my 6" rotary table (vertical) as well as angle plates (4", 6", 8"), clamps. slip guages, 1-2-3 and upward blocks, cylindrical squares etc. etc. on the glass plate on the mill table with plenty of room for marking out and setting up or measuring etc.etc.
    The glass surface is very hard and using it meant that I only needed a smaller, lighter, cheaper surface plate which does not get abused as it might be if used for marking out or setting up etc.
    I can get more glass as required as I pass the glazier several times a week as he is only about 5Km (~ 3 miles) from here.
    Float glass surface flatness is in the order of 0.0001"/" ie one tenth per inch and its all that's needed more often than not.
    It can be used to put a sheet of "wet and dry" cutting paper (use "wet" with turpentine) for cleaning up or "flattening" a surface. Many small motor shops do just that on cylinder heads.
  9. #679
    Mar 2010
    Elizabeth City, NC
    Peter.
    I bought it from:
    How much for the same size that you have?
    HAP
  10. #680
    Saskatoon, Saskatchewan
    Quote Originally Posted by Black_Moons
    I just checked...they list one for C$35 on sale.
    SURFACE PLATE 12" X 18" X 3"
    Item No: B1321
    Precision Surface Plate - Black Granite
    Harder than steel
    Does not nick or burr
    Retains accuracy for years
    No Ledge
    Size: 12'' x 18'' x 3''
    Accuracy: + .0001
    For that price, it's hard to justify p*ss*ng around with "make-do's" instead of getting the real thing....IF that spec for accuracy is actually true.
