Page 86 of 315 FirstFirst ... 3676848586878896136186 ... LastLast
Results 851 to 860 of 3145
Thread: Shop Made Tools
  1. #851
    Mar 2006
    Mississippi
    Default Spin Index
    Glenn105
    If you pull the shaft out as you describe would you loss the rotational position ? The pin is not very long
    John R
  2. #852
    Nov 2010
    Default John R - rotational position?
    Hi, john -
    I'm not sure that I understand your question. The only pin that is used with these Spin Indexers is the LOCK PIN for setting the index at a particular angle. This would be for grinding a flat or other feature on a shaft held by the 5c collet.
    What I was talking about is if you are SPINNING a shaft using the handle at the back of the spindle to fully grind the diameter of the shaft. You would NOT use the lock pin at all when spinning these indexers. It's the LOCK RING at the rear of the spindle that I was saying you can slide back by loosening the set screw. Then re-tighten the set screw when the lock ring is set wherever you need it to be. This will give you however much travel you want on the spindle to be able to grind longer sections of the shaft to a particular diameter.
    -Glenn
  3. #853
    Mar 2006
    Mississippi
    OK Now I understand
    thanks
    John R
  4. #854
    Jul 2002
    Central Western NSW, Australia
    Tailstock turret for the Myford
    .. with tooling
    Tel
  5. #855
    Nov 2003
    Vancouver, WA
    Copied couple of tools already shown, same principle only a little different.
    Copied ehughes for holding small parts to silver braze. One end has screw to move carbon in or out of thin wall brass tube and other end is spring loaded to push against first carbon.
    Copied Wierdscience's band saw circle cutting jig. Mine is for a smaller 16" Walker-Turner saw and not as ridgid support where it clamps on, but on inital test seems it will work good.
    Shown in use the jig is clamped round shaft with flat on one side that holds upper bearing guides,
  6. #856
    Jun 2010
    NC
    Default drawbar hammer really simple
    After reading Boot's post about z axis height on the mini mill I decided to check mine. Since I'm still unemployed I haven't picked up any holders or endmills and have just been using the mill as a drill press. I knocked loose the chuck with a piece of wood and figured I needed an actual hammer so I looked through the metal I have, thanks to David h, and found a rod of brass and a tube of brass.
    I turned down the rod to fit the tube and used the remainder of the rod for a partial handle. I planned to solder the rod into the tube but the fit was tight enough that I had to drive it in with a 5pd sledge. I tried to solder it but using white flux and plumbing solder had no effect, the solder just balled and slid off the brass. Is there a special flux or solder for brass?
    I took a picture of the drawbar hammer, note the skull crusher end because anything with a skull crusher is just better. No split in the handle just wood grain.
    Jim Doherty
  7. #857
    Montezuma, IA
    Jim, 98% of the time when solder balls up rather than flowing, you've got the workpiece too hot. Lead-tin and tin-silver solders generally melt & flow at around 450 to 600 F, depending on the alloy composition. I prefer to use paste flux such as NoKorrode for soft solders.
    David
    David Kaiser
    ― Robert A. Heinlein
  8. #858
    Jul 2007
    West Michigan
    Quote Originally Posted by 38_Cal
    David
    David,
    I was going to say the workpiece is probably not hot enough.
    Usually if the workpiece is too hot, the filler will boil and roll off.
    Unless a torch is being used, I doubt that too much heat is the problem.
  9. #859
    Champaign-Urbana, Illinois
    David
    I was going to say not hot enough as well, especially given the mass of the head. You were probably melting the solder with the flame and it wasn't flowing because the part was too cold.
  10. #860
    Nov 2009
    Gold Country, CA
    Quote Originally Posted by Tel
    .. with tooling
    Very nice tailstock turret. Did you use plans from somewhere or create on your own? I would like to make one someday and this certainly is inspiring.
