Page 347 of 348 FirstFirst ... 247297337345346347348 LastLast
Results 3,461 to 3,470 of 3480
Thread: Shop Made Tools
  1. #3461
    Mar 2015
    Central Ms
    Quote Originally Posted by Alpino View Post
    Hello everyone. For some time I have been following you from Italy. You are an inspiration for me. I will post something from my workshop shortly, as a contribution to the beautiful forum.: D
    Bon Giorno Alpino. I for one look forward to posts from your shop.
    Lewis Grizzard
  2. #3462
    Dec 2018
    Italy (Padova)
    Default Jig
    Here is a job for my welding and multipurpose clamps that I get from parts of Denver's bandit machine. I needed the Manetti i for sighting, I built the jig to make enlargement in one fell swoop and with a better finish.
    PHP Code:
    IMG 20181229 233042
    PHP Code:
    Resize 2018 12 30 00 07 30 011
    Bridgeport cutter mill 2j
  3. #3463
    Mar 2015
    Central Ms
    I don't see the pix.
    Lewis Grizzard
  4. #3464
    Apr 2003
    Greenville, SC
    I made a toe jack and skate set:
    The skates are made from 3" square tubing from the roll bar of a bulldozer, with 5/8" dill rod and 8 99502H bearings pressed on.
    The toe jack is a Harbor Freight 8 ton jack and a mixture of 1/4, 1/2, and 3/4 bar stock.
    All I had to buy was the jack, springs, drill rod, and bearings.
    I drilled through the two parts of the handle and pressed in a roll pin to stop them from separating.
    The rubber "tread plate" is to reduce the sliding of the skates under the machine due to variations in the floor taking some of the weight off of any one of the skates. (I hope it works that way, it is basically an experiment).
    The jack is a 8 ton unit. I know the assembly will not handle that kind of weight, but I figured the extra diameter of its ram and cylinder would better handle the radial stress.
    Edit, enlarged picture and corrected verbiage.
    Finding creative ways to turn material into scrap for decades.
    Current Machines:
    South Bend 13” Lathe (being rebuilt)
    Bridgeport Mill (step pully J)
    Garvin 2A horizontal mill
    Ohio 20” shaper
    Harbor Freight 4x6 band saw
  5. #3465
    Dec 2004
    East Coast, USA
    Not really a shop made tool, but they are very useful around the shop. Got some tools that often need an Allen wrench or two for general use? Stick one of these on the machine and they magically hold the Allen wrench on the machine already ready to be used. Need to find studs in a wall or ceiling? Let a bunch of these show you the location and direction of the studs (nails/screws). I also "soft" mount things so the side of machines with 4 of these on each corner of the magnetic item -- like soft mounting an electrical box so it "breaks-away" if under stress. The steel cabinet door on my surface grinder didn't stay closed by itself until I tossed one of these little guys on the inside lip of the door -- now the door stays closed with the help of some magnetic force. Changing the oil in your machines? Drop some of these in there to help some of the floating bits from circulating around your gear boxes... Are you dying to give yourself a really good finger pinch? Let two of these guys do it for you... Many, many uses around the shop...
    1/2" x 1/8" Neodymium magnets (If link is broken just search for the prior text)
    https://www.ebay.com/itm/12-100-500p...c/302030262749
    1/2" x 1/4" Neodymium magnets (If link is broken just search for the prior text)
    https://www.ebay.com/itm/5-10-25pc-1...c/302030266388
    Work hard play hard
  6. #3466
    Jun 2013
    marina del rey
    MH--I like the machinery moving set.
    12" x 35" Logan 2557V lathe
    Index "Super 55" mill
    18" Vectrax vertical bandsaw
    24" State disc sander
  7. #3467
    Nov 2017
    Watford, UK
    I hate the idea of attaching Allen keys to machines with magnets. Partly because everything being/getting magnetic is one of the banes of my shop; but at least in part due to the fact that I tried this idea with a drill chuck key...and just repeatedly ended up with an empty magnet and a missing chuck key. This could just be my utter failure though!
    I love the idea of (temporarily) marking the screws in stud walls though. Genius, that!
  8. #3468
    May 2017
    New Jersey
    Default Pin vise
    I made a shop made pin vise. Have been using it for some time. I love it. Images and video attached.
    12x16" Delta 3d printer (Built from scratch)
    Logan 825 - work in progress
    My Blog - http://engineerd3d.ddns.net/
    Youtube Channel - https://www.youtube.com/channel/UCVY...view_as=public
    Instagram - https://www.instagram.com/engineerd3d/?hl=en
  9. #3469
    Dec 2016
    Helsinki, Finland, Europe
    Make me want to marry pump action screwdriver and countersink/deburr
  10. #3470
    Aug 2007
    Custer WA
    I use one of these in low gear, works great.
