Page 348 of 349 FirstFirst ... 248298338346347348349 LastLast
Results 3,471 to 3,480 of 3487
Thread: Shop Made Tools
  1. #3471
    Dec 2016
    Helsinki, Finland, Europe
    Quote Originally Posted by Michael Edwards View Post
    I use one of these in low gear, works great.
    https://images-na.ssl-images-amazon....L._SL1000_.jpg
    Small makita is what I'm also using.
  2. #3472
    Jul 2007
    West Michigan
    I use a DeWalt 18 volt drill for a lot of hole deburring but also have a hand tool to hold a countersink for use on the lathe.
  3. #3473
    Mar 2015
    Central Ms
    I wish my Dewalt drill had 3 LEDs like that. The single led on the Dewalt is more of a hindrance than a help. Creates a shadow that hides the target.
    Lewis Grizzard
  4. #3474
    Dec 2004
    East Coast, USA
    Quote Originally Posted by Dave C View Post
    The new Dewalt driver have 3 leds
    Work hard play hard
  5. #3475
    Apr 2003
    Greenville, SC
    Quote Originally Posted by ezduzit View Post
    MH--I like the machinery moving set.
    Thanks, ezduzit.
    Finding creative ways to turn material into scrap for decades.
    Current Machines:
    South Bend 13” Lathe (being rebuilt)
    Bridgeport Mill (step pully J)
    Garvin 2A horizontal mill
    Ohio 20” shaper
    Harbor Freight 4x6 band saw
  6. #3476
    Dec 2009
    Stevens Point, WI
    Not really a shop made tool, but they are very useful around the shop. Got some tools that often need an Allen wrench or two for general use? Stick one of these on the machine and they magically hold the Allen wrench on the machine already ready to be used. Need to find studs in a wall or ceiling? Let a bunch of these show you the location and direction of the studs (nails/screws). I also "soft" mount things so the side of machines with 4 of these on each corner of the magnetic item -- like soft mounting an electrical box so it "breaks-away" if under stress. The steel cabinet door on my surface grinder didn't stay closed by itself until I tossed one of these little guys on the inside lip of the door -- now the door stays closed with the help of some magnetic force. Changing the oil in your machines? Drop some of these in there to help some of the floating bits from circulating around your gear boxes... Are you dying to give yourself a really good finger pinch? Let two of these guys do it for you... Many, many uses around the shop...
    1/2" x 1/8" Neodymium magnets (If link is broken just search for the prior text)
    https://www.ebay.com/itm/12-100-500p...c/302030262749
    1/2" x 1/4" Neodymium magnets (If link is broken just search for the prior text)
    https://www.ebay.com/itm/5-10-25pc-1...c/302030266388
    I got:
    The seller's store is closed for vacation. Check back later.
    Dec 2008
    Kendal, On
    Shop made HVAC crimping pliers.
  8. #3478
    Quote Originally Posted by Dan Dubeau View Post
    What did they start out as?
  9. #3479
    Dec 2008
    Kendal, On
    Quote Originally Posted by Joe From NY View Post
    linesman pliers. http://bbs.homeshopmachinist.net/thr...for-old-Pliers
  10. #3480
    Dec 2009
    Stevens Point, WI
    Those are slick! Nice thinking!
