Ok here is the deal. I have a 5hp 240v lathe and I have a 5hp rpc that I run
my mill on. The lathe will start up and run on the rpc but starts slow in
the higher gears. I have a 2nd 5hp motor I can use for a 2nd idler, will
this help with the slow start up if I add run caps to the 3rd leg just like
the current rpc? If I have my mill running when I start the lathe it does
not seem to make a difference, but it does not have the extra run caps.
This is the info I used to build the 5hp rpc.
http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
I didn't really want an RPC big enough to run the lathe running all the time, nor did I want to fool with a start circuit big enough to cold start a 10+ hp idler. My existing start circuit could handle a 5hp start with only the addition of some bigger caps. And once the 5hp is running, I use it to start a larger 10hp idler. I used some relays and A-B momentary switches in a NEMA (?) cabinet to allow me to start the 5, then (only when the 5 is running) start the 10. Once it's running, I can drop and pick up either idler at will. Then there is one big red "e-stop" that shuts down the whole thing. Complete build with schematics pictures and discussion is over on PM in the RPC forum.
