Results 1 to 10 of 15
Thread: odd size chuck key
    Feb 2009
    Mobile, AL
    Default odd size chuck key
    I bought an old Cushman 4 jaw off fleabay and it requires a chuck key bigger than 1/4", smaller than 5/16". The i.d. of the socket is about .290 across the flats. Is there such thing as a 9/32 key?
    I may make one from a hardened pin but I don't have a mill so it will not be a quick and easy job for me.
    Regards,
    Roland
    Toledo, Ohio
    Chuck keys do not necessarily follow any dimension standard. To make it more complicated, they are often tapered to boot. It is a good learning project for file work.
    I built this one and didn't have a mill yet. Used a side grinder with a cut off wheel.
    Quote Originally Posted by rmcphearson
    as a general principal, make the part you want wear soft....better to have the key get messed up over time rather than the chuck...I'd make the key from mild steel.
    its an easy job to file a square section on the end of a round bar of mild steel
    Lexington, Ohio
    Or turn a piece about the right size then beat it into the chuck key hole with a big hammer, wiggling it from time to time so it don't get stuck, kinda like broaching in reverse.
    Just kidding, just kidding
    Buffalo NY
    That's a good way to break a pinion or worse.
    --Doozer
    Lexington, Ohio
    Quote Originally Posted by Doozer
    --Doozer
    Hard to believe any one could take that seriously Doozer, especially with the "Just kidding, just kidding "
    at the end.
    Buffalo NY
    Sorry, as soon as I read about hammering........my eyes totally glanced over the "just kidding" part. Sorry bout that.
    --Doozer
    Lexington, Ohio
    --Doozer
    HaHa, yeah, it was meant to be like that, almost didn't put the just kidding part to see what the replies would be but didn't want to appear dumber then I really am
    Buffalo NY
    It's sorta like walking down the sidewalk and seeing a car accident happening, and you miss the $20 bill just laying on the sidewalk.
    --Doozer
