Originally Posted by
Jack772
...I saw where some of them came with a 7 inch 4 jaw chuck. Mine didn't have one so I figured a 6 inch 4 jaw chuck would work just fine...
You didn't miss much. I have the Jet version and the 4 jaw was just about unuseable. I used it 1 time and spent close to an hour trying to get the stock properly centered. Everytime you touched it, everything moved resulting in lots of tail chasing.
I bought a new Bison 6" 4-jaw for it and haven't looked back. It only takes a minute or two to get things dialed in now and it doesn't marr the stock like the original did.
I also bought a 6" Bison 3-jaw at the same time. It's a lot heavier than the 4 jaw and it simply hasn't been an issue. The 9 x 20's use tapered roller bearings about the same size as the front wheel bearings GM used on full sized cars where loads are considerably greater than anything you could put on that lathe without destroying it.
The early bird may get the worm but the second mouse gets the cheese.
