Originally Posted by
PaulT
Beanbag is giving good advice here. Mills using the APKT type inserts cut much better on BP sized machines than the old TPG inserts. The geometry of the insert just works better, its a much more modern design.
They work really well on both steel and aluminum with the right inserts, you can get some ground and polished APKT inserts for aluminum that give really good surface finishes. I'd send the TPG mill back, even if you have to eat the shipping costs.
Enco really should stop promoting TPG tooling to home shop users, pro's have moved away from it a long time ago, the newer design inserts just work better, both on small and big machines.
Paul T.
