Results 1 to 10 of 40
Thread: "Nominal Current" question
    May 2007
    Live Oak, TEXAS
    Default "Nominal Current" question
    My VFD has a parameter setting for "Motor Nominal Current - Allowed Range .2 to 2.0 * /2nA (must be equal to value on motor rating plate).
    HUH ????
    My motor plate has nothing labled about "Nominal Current".
    230volt
    5.8 Amp
    60Hz
    3 Phase
    2Hp
    Ser. F. 1.15
    Rating 40c
    What should I enter for this parameter?
    Palmer Alaska
    Strange wording
    I would just put in 5.8
    If it won't take that, than 1.0
    Apr 2008
    winnipeg/manitoba
    Are you sure your VFD is sized for your motor? Nominal current should be the nameplate rate. If it is rated for 6 Amp-then enter the highest nominal value. If the VFD is not rated for 6 amps-then you will have a problem...
    May 2007
    Live Oak, TEXAS
    Nope, the VFD is rated at 16.8 Amps, 240 volt.
    So I guess I should enter the Amp rating- 5.8?
    Woodinville, WA
    Yes.. it's just the nameplate current. It's "nominal" because any motor can exceed this number... The VFD is smart enough to allow short term overloads based on this number.
    Apr 2008
    winnipeg/manitoba
    Are you sure about the 0.2 to 2.0 value? The "must be equal to motor nameplate", is the right answer. Your values above are whats throwing a bit of caution into the mix. If the drive accepts your nameplate value 0f 5.8 Amps-then you're golden Nothing like commissioning to lose some hair over.
    May 2007
    Live Oak, TEXAS
    Yeah, the ".2-2.0" value is in the operator's handbook. The handbook is written for European settings, not U.S.A.
    If the handbook were published in the U.S. it would be in 5 different languages, with 5 different conversion equivalents. Political Correctness.
    Wenatchee, Washington USA
    Kidd,
    Is there anywhere in the setup to enter 'motor full load' current? If there is then the above mentioned setting MIGHT be for the service factor (SF) on your nameplate. This is just a maybe... I really have no idea from your description. I would call ABB's support line, the number should be in the book or on-line if the book only lists European numbers, and ask them what it means. I have seldom had to call ABB but when I have they were very helpful and knowledgeable.
    Edit: I found the link to the manual in your other post and the answer is...... I have no idea what they want . I would call ABB in the morning and have them explain what they want. If you do call and get the answer PLEASE let us know what they said. I would really like the answer explained to me.
    Robin
    Looking at the ACS320 manual, page 129, code 9906 motor nominal current
    the setting of 0.2 to 2.0 is with reference to the drive current.
    So you should be able to put in the motor current as per the nameplate. the drive will either accept it or not, depending on what the rating is. If the drive is suitable for your motor, as it seems it should be, it will take it.
    May 2007
    Quote Originally Posted by KiddZimaHater
    Nah - them's probably Euro-Amps. They's bigger than U.S.A. amps. Probably metric, too. Maybe you gotta multiply or divide by Pie or sumthin.
    -bill (Who is waiting for Nurse Diesel to come with his injection)
