Results 1 to 8 of 8
Thread: Three or Four jaw self centering
    Feb 2009
    West Virginia
    Default Three or Four jaw self centering
    I do not have a three jaw chuck for my old SB 9", but... I have a four jaw independant and a four jaw self centering. Niether are world class, but they both work well. Any real reason to purchase a three jaw chuck? Any advantage (or disadvantage) of having three verses four with self centering feature?
    THX
    Mar 2009
    Sweden
    Easier to hold hex stock and other shapes dividable by 3?
    Dec 2002
    Friesland, Netherlands
    Only reasons I can think of ar ethat 3 jaws will always grip, whereas a 4 jaw might be tight on 2 jaws, loose on 2 others. If yours grips round bar ok, then don't worry.
    Also, 3 jaws will hold hex bar, nuts etc - but for the number of times you probably need that, use the independant chuck.
    Ian
    All of the gear, no idea...
    airsmith282 Guest
    i have only the 3 jaw and i do like it but 4 jaw as it advantages for both the indepentdent and self centering, the 3 jaw chucks are good for round triangle and hex but thats about all they are good for..
    Feb 2009
    West Virginia
    Have never needed to chuck up a hex shape yet, but hadn't though about that aspect. So far though, it doesn't seem justify a three jaw for me.
    The four jaw seems to hold a round just fine.
    Canada, Bc
    garagemark: stick with the 4 jaw, if you have a mill you could make some 60 degree 'v' blocks to hold hex in it without maring the corners.
    Maybe put a 3 jaw on the 'buy if I find a good one for cheap somewhere' list.
    Never seen a 4 jaw self centering, must be kinda nice.
    Sep 2009
    My independent 4 jaw has not left the lathe since they got married. I suppose I might take it off if I had to do a bunch of hex, but for one or two, probably just use the 3 jaw on the RT and make a round nipple on the hex to grab with the 4 jaw. Indy 4 takes seconds to reach the accuracy of a three jaw, seconds more to get almost no runout.
    Many years ago, when I was learning the machine trade, the lathe I had to work with only had a 4 jaw independant. I believe that was a good thing, because I didn't know any better and I got very comfortable with chucking up most anything with it. Now that I am retired, I have a small 13X36 lathe here at home and I have both the 3 and 4 jaw. However, my favorite is and will always be the independant 4 jaw. I have heard of the self centering 4 jaw, but don't believe I'd ever have the need for one.
