Results 1 to 9 of 9
Thread: cutting 30 threads per inch
    Mar 2002
    Kirkland, Washington
    Post cutting 30 threads per inch
    I need to cut 9/16-30 Whitworth threads with my 9 SB with a quick change gear box. There is no 30TPI so how do I do it?
    Toledo, Ohio
    You will have to change the stud gear. You can calculate the number of teeth needed, or contact South Bend, and they may tell you. They will probably be very happy to sell you the necessary gear.
    Oct 2001
    FWIW...& not much help for u ,unless u have access , but the atlas /craftsmn quick change box has the 30 tpi available ,remembered from the win. model 12 thrds i have cut......ck w/ ur buddies
    best wishes
    docn8as
    docn8as
    52N 122W Western Kanuckistan
    Whoa,
    Docn, you have been spending too much time either text messaging or on ham radio
    Sep 2001
    Birmingham, AL
    Marvin Klotz' site has a program you can
    unzip that you can plug in the gears you
    have and TPI needed and calculate the closest match. Change.zip
    www.geocities.com/mklotz.geo/
    Steve
    Steve
    Step,
    Have you got a 10tpi, or a 15tpi shown on the gearbox? If you have, then if you reduce the input gearing by 3:1 you can use the 10tpi selector position or a 2:1 reduction will allow the 15tpi position to be selected.
    Other tpi's will produce the same results with respective gearing.
    RR
    [This message has been edited by Ragarsed Raglan (edited 10-29-2003).]
    Toledo, Ohio
    For some reason, South Bend seems to have skipped the 15 thread combination. That is why a calculation is necessary. You need to know the leadscrew TPI, and the tooth count of the gear train to work it out. Klotz site may help. S/B can also.
    Tony's lathe site or Yahoo groups probably have info. also.
    BTW, Good to see you back docn8. Haven't tried making a chamber reamer yet, but at these prices, I'm not far from it.
    [This message has been edited by JCHannum (edited 10-29-2003).]
    Maine
    There is/was a standard South Bend gear available to do this, as it also allows you to cut 27tpi for 1/4-27 pipe thread. I don't recall offhand what the number of teeth on the gear is, but SB should indeed be able to help you out with this. I think the SB book "How to Run a Lathe" may even talk about this.
    Mar 2002
    Thank you for the help. All I really needed to do was look at my Enterprise lathe and find it has a 30 pitch setting.
    Thanks again
    Pete
