Results 1 to 10 of 14
Thread: building up a shaft
    Default building up a shaft
    As some of you may know I've been rebuilding a chevalier tool and cutter grinder. There's a jack shaft in the motorized workhead that was problematic...disassembly reveals the two diameters that mate with the roller bearings are small - one end is .003" and the other .007" . (after doing a ground up restoration, my opinion of this company's products is that the should have chosen harbor freight as their distributor , well at least the bearings are mid range quality)
    Ok, question is, how to repair. I'd make a new shaft, but threads are metric and custom and my lathe isn't set up for them...I may still go that route but am interesting in trying a welding repair. any precautions to avoid warping the shaft? i've a mig welder; just lay down a around the shaft (figuring out how to rotate it while welding)? the bead is typically easy to machine?
    I haven't done this before so am looking for the tips and hints on how to make it a success
    thanks
    John Stevenson is the go-to guy for experience with shaft build up and restoration.
    I also seem to remember thin sleeves available for needle bearing inner races that might have some application.
    Are you positive there isn't a way to persuade your lathe to produce a metric thread? I do metric with some regularity on an old Atlas. And (since you have an affinity for special tooling) there's that slide mechanism to produce ANY thread you want. It's essentially a secondary longitudinal slide under the compound linked by a bell crank to a track fixed to the bed. This track can be angled so the thread actually cut will lag or lead the thread set by the leadscrew. I'm not sure I've saved any pictures but can probably track something down if it's not clear and you're curious.
    NL
    Hi
    I usually try to avoid welding.
    Had an old guy/instructor once tell me
    'welding is aways your last choice'
    Anyway:
    First turn the shaft down to appro 0.050 to 0.100" under the bearing fit size
    Use mig , around ,and let cool slightly between welds to TRY and prevent wrapping.
    When finished,let it cool slowly on its own.
    Chuck up, clock in and turn to a bearing fit.
    please visit my webpage:
    http://motorworks88.webs.com/
    Stevens Point, WI
    I would also try to sleeve the shaft if possible. if you can turn the shaft down a bit so you can build a thicker more workable sleeve to press on the shaft.
    I turned and pressed a sleeve on my new acme screw for my BP grinder.
    New shaft on top:
    Is it possible to use American thread or are there special nuts involved?
    Owensboro KY
    Welding will only result in a very warped shaft. As I see it you have two choices:
    1) Make a new shaft (maybe someone on the forum could do the threading)
    2) Have the old shaft plated. Tank plating is not your only option, nor is hard chrome. Check around to see if there is someone in the area that has brush plating. When I was stationed on a repair ship in the US Navy I was sent to the Dalic Brush Electro Plating school in California. Even in the less than optimal ship board conditions we could hold size on a bearing housing or journal to plus or minus .0001" on the diameter. Our "rule of thumb" was if it was less than .025"/side we plated, over that we spray welded.
    VPT also has a good idea. Just use a shrink fit and finish turn the OD after assembly.
    Mar 2009
    A pic of the shaft and it's use would be helpful.
    If you desire to maintain any form of concentricity with other features on the shaft, I would grind, plate, and finish grind to size the damaged areas. Sulfamate Nickel, Electroless Nickel, or Hard Chrome. I use mainly hard Chrome as that's what the prints usually call for, but Electroless Nickel is excellent for such repairs.
    I cant imagine a guy that scrapes everything for accuracy wanting to weld on a shaft....
    TGT, story of my life, stopping making one tool cuz i need to make tooling to make the tooling to make the tooling I would be interested in the lathe device you mentioned, maybe worth starting a thread on it? on this one though I think I will make a new shaft, thread the ends imperial and make the nuts it needs
    thanks guys....I'd turn down and sleeve but on one end but it would meaning turning down threads as well....by the time i sleeve both ends and do the threads, easier to make a new shaft and nuts....this is good ....i've been scraping for months, time to make some chips...I hope i remember how to turn the lathe on
    Stevens Point, WI
    I'd like to see progress pics.
    Jun 2006
    Austin, Texas
    Quote Originally Posted by Mcgyver
    Michael, you still have that Standard Modern, don't you? That's easy to put a conversion gear on the banjo. Bruce Griffing has one on his.
    I'd make a new shaft, rather than plate and re-grind. I've got a commercial electroless nickel kit, but they recommend a maximum thickness of 2 thou.
