Page 246 of 251 FirstFirst ... 146196236244245246247248 ... LastLast
Results 2,451 to 2,460 of 2501
Thread: What did you do today?
  1. #2451
    Mar 2015
    Central Ms
    Good, safe, job DennisCA. I agree with your method. That's a lot of weight to handle. Have fun with your new machine.
    Lewis Grizzard
  2. #2452
    Oct 2012
    San Antonio TX, USA
    finished a major job this week - adding new lights and a fan to the kitchen, partly because I wanted a more mellow set of lights than the 4x4ft LED tubes in the overhead recess and partly because I found it really annoying having to walk around to the other side of the kitchen in the dark to turn the lights on.
    I didn't actually plan how long a light strip I needed for the kitchen, so it turned out the 5m strip of 2700K high CRI (supposedly) wasn't enough. Got around that by cutting the strips into their 3 LED units and spacing them apart on the under counter lights (alu strip from a closet door rail, believe it or not). Was super tedious wiring them all together.
    light strips for the overhead light
    dimmers (one for under counter lights, one for overhead) and 2nd power supply. The first one lasted an hour as it was a 24W unit with a 60W sticker on it. That'll teach me.
    under counter strips with some diffuser plastic (bulk trash find) as a cover, mounted on stand offs made from a piece of small diameter metal pipe (possibly from a toilet roll holder)
  3. #2453
    Oct 2012
    San Antonio TX, USA
    dim shot of the overhead light so you can see where the strips are
    bright shot, I like the light colour. You can also see the new fan that I installed. Running the wire for that was not fun and required machining some adapters so I could use my socket extensions to hole saw a hole in the side of the box between the light recess and fan hole.
    one side of the kitchen
    and the other
  4. #2454
    Oct 2012
    San Antonio TX, USA
    and some lights under the island more for fun than anything. Makes a nice "don't walk into the dishwasher" light for the nights.
    now onto the next project, a new work bench
  5. #2455
    East Coast, USA
    I finally finished sorting and labeling all of my small hardware (#2-#10, M2-M6). Everything larger is up in my mezzanine and I'll finished labeling that this weekend.
    Work hard play hard
  6. #2456
    East Coast, USA
    My small metric hardware, and set screws, and misc
    Work hard play hard
  7. #2457
    Oct 2013
    USA MD 21030
    Key "Stalk"?
    I got some bronze bushings from AliExpress:
    I found an interesting little booklet my father got when he was in Germany during WWII:
  8. #2458
    East Coast, USA
    Key "Stalk"?
    Whops, I'll fix that
    Does anyone know what you call these types of nuts? It's like they are some type of rivet nut but not sure. There are some threads inside then. Unfortunately my fasteners book doesn't mention them.
    Work hard play hard
  9. #2459
    Sep 2018
    Texas
    Hi Loks.
    High tech aircraft fastener nut in the left bin. The bolt has a flat head and is made to close tolerances. Hole is reamed and the bolt is tapped into place and the nut is tightened with a special tool til the back part breaks off.
    Not useful for much else besides fastening metal structures in aircraft, AFAIK.
  10. #2460
    East Coast, USA
    Quote Originally Posted by Dane Bramage View Post
    Hi Loks.
    Ah yes, thanks! Some of this hardware came from my Dad and I bet he got these from Boeing surplus when we lived on Mercer Island, WA many years ago.
    Work hard play hard
