Page 440 of 450 FirstFirst ... 340390430438439440441442 ... LastLast
Results 4,391 to 4,400 of 4498
Thread: What did you do today?
  1. #4391
    Saskatoon, Saskatchewan
    A while back I broke a couple of teeth off the small gear end of my first South Bend lathe's backgears and ever since then I simply never used backgear. What a pita on certain jobs! Also quite a while back I acquired a second 9" SB and just last year started a very slow clean up of it. It also was suffering from the same malady as my first one and since I had it apart, I fixed it by having a friend braze it up and then I recut the missing teeth with a cheap but very adequate made in China gear cutter. Today I finally got teed off enough to swap the two backgear clusters.
    When I had it apart I cleaned everything and oiled the bejeezus out of it which made the eccentrics move much easier, so much so that it would disengage from the force generated by the 14 1/20 pressure angle. I did a bit of research on the interweb and found I should have a bolt on the right hand side of the headstock that would press against a spring which would press against a brass plug which in turn would press against the side of that eccentric and the friction would stop the disengagement. A closer look (after I disassembled the backgear again) showed I had the bolt and the spring but no brass plug so I quickly made a small brass plug with a little tit on one end to center it on the spring. Long boring story short, I now have a working backgear!
  2. #4392
    Aug 2004
    Sunny So Cal
    Not too bad for first try:
    50/50 ordinary wheat and Spelt Wheat. Wifey and 6 year daughter have gone trough the large loaf already
    Now that is what bread should look like. Very satisfying. Butter???? JR
  3. #4393
    Nov 2006
    durban s africa
    Quote Originally Posted by Arcane View Post
    What did you braze it with.
  4. #4394
    Plunger, my friend used a generic brazing rod that's good for a variety of metals but I don't know for sure what it was specifically but I suspect it was a brass rod.
  5. #4395
    Helsinki, Finland, Europe
    Thanks. Yeah, best with only butter or amazing even just as is.
    Pure sourdough recipe and Spelt/Dinkel/hulled wheat seem to give it lots of taste and the texture/firmness is really nice. I hate soft bread but this needs real workout with jaws when eating!
    And what did I do today? Baked my second set of sourdough:
  6. #4396
    Oct 2012
    San Antonio TX, USA
    man you are on a roll!
  7. #4397
    I turned in my bottles today at Sarcan and got my deposits back. C$425.
  8. #4398
    Sep 2004
    Oregon Coast
    Picked the ripe peaches from our tree, removed a old trellis that the SHMBO wanted gone. Made 4 gallons of laundry soap and sat in the shade and hid from SHMBO.
  9. #4399
    Oct 2005
    British Columbia
    Holy cow!
    And I think I have a drinking problem when I turn in 25 bucks worth. LOL
  10. #4400
    Mar 2015
    I looked at my credit card balance today... For the next 10 months, no new toys for me!
