Page 457 of 459 FirstFirst ... 357407447455456457458459 LastLast
Results 4,561 to 4,570 of 4585
Thread: What did you do today?
  1. #4561
    Busy folks you are....
    My only accomplishment today, or really for several gays, is confirming that it will be a number of weeks before I can get a cap for the new truck. And that I have plenty of time to get the Line-X in the bed of it, no worries about the cap.
    I had determined that I needed the cap first, and could get the Line-X anytime later, of course, so this just inverted the priorities. Apparently, now that 2019 is nearly over, the cap companies still have no caps available in the type I want for the 2019 Ranger 6 foot bed. Go figure. For the 2000 S10, no problem.... probably because that had been made a few years with few changes.
    maybe I will get down to the shop and get a few rounds of scraping done on the current project. Still waiting on the straightedge needed to get the Rivett 608 bed started, but it is due in shortly. I better get the mill table and carriage off the bench all done soon.....
    Quote Originally Posted by Tim The Grim View Post
    12 Hr shift. 6 am - 6 pm.
    According to my iWatch ...
    18,432 Steps.
    9.23 miles.
    21 flights of steel steps.
    1.5 bicycle miles.
    Isolated, de-pressured, triple nitrogen purged and LOTO a Worthington 4 stage high pressure Hydrogen compressor.
    Made HUGE flames come out of the Hydrogen System flare tower while purging.
    Climbing on stair ladders above grade and crawling on hands and knees under the deck to close 33 valves.
    Avoided having my personal H2S monitor get me in trouble while opening 8 bleeders.
    (Watching steam leaks and the LOTO tags sway in the breeze so I could stay upwind to avoid the hydrocarbons and muckey stuff spraying out)
    Threw down and filled 18 five gallon sewer covers for Hot Work.
    Helped a trainee de-gas a pump and generate various work safety permits.
    Pulled and ran multiple tests on cooling tower and steam generator water samples.
    Took delivery of 400 gallons lube oil.
    Made a perchlorethylene, isopropyl alcohol, high octane blend stock mix for reactor catalyst activity level.
    Drained assorted knockout drums and waste oil collection points.
    Wrote a turnover and gave a verbal to my relief Op.
    Drank 5 cups of coffee, 5 bottles of water and a Powerade.
    Had a 20 minute lunch.
    19 more shifts ‘til I retire.🥳
    Some kids on this forum will be restoring you in 2070 since you're clearly a machine.
  3. #4563
    Oct 2013
    USA MD 21030
    Continuing my yard cleanup and preparation for the shed I plan to build. I made a place to store my mowers, temporarily, at least. Put down some 8x16 pavers to keep them off the mud:
    And I made a little "porch" on the side of the old woodshed for another mower. It will need to be moved when I build the 8x12 shed:
    I was separating the rubble from the old foundation into usable rocks and bricks, and concretre chunks. I found this embedded in one piece:
    I was able to bust it out - an old flat iron!
    I cleared most of the area where the shed will be. Rocks are up the hill on the right:
    And the concrete rubble. Not sure what to do with it. I may use the rocks for a retaining wall on the hill behind where the shed will be, and maybe some of the concrete rubble can be used as well, although it's rather ugly:
    I also have an old shovel that I think was my grandfather's, possibly from 1920s Germany:
    I used some cold galvanizing compound on it to help preserve it. It's an antique, but I still use it. I got this can of Rustoleum and two others, free, from a neighbor:
  4. #4564
    Nov 2017
    Watford, UK
    ...or 'stock' as we spend-thrift machinists call it!
    Looks more like a trench-digging spade to me. Could you braze the crack(s) to give it a little more stability? These days you'd just replace it but I figure it has some sentimental value to it given the story.
  5. #4565
    Dec 2017
    Bemidji, MN
    Quote Originally Posted by Cenedd View Post
    You could braze it but welding works pretty well too. I have welded a couple of my spades that cracked like that.
  6. #4566
    Nov 2017
    Watford, UK
    Quote Originally Posted by RMinMN View Post
    Ah. Wasn't sure if it was too thin to weld easily. I have a stick welder and have welded a whole 12 inches of test bead....so I'm really well educated in this field Thought brazing would be a lower heat so as not to blow out the steel of the spade. If a blat from a MIG gun would do it, it'd be quicker, I'm sure.
  7. #4567
    May 2013
    UK, near London
    Amazing that the handle is still in such good condition. We get a lot of old forks and spades given to us in the Men's Shed with rotten shafts but the cost of a piece of good wood for a replacement is more than the cost of a new stainless implement. We have therefore only repaired a couple that had sentimental value for their owners.
  8. #4568
    Dec 2017
    Bemidji, MN
    I didn't say it would be easy to weld, just that it is possible and that I have done it. A MIG welder would probably work better than the stick welder but since that is what I had, that is what I used. I had welded a bit before I tried a spade though.
  9. #4569
    Jun 2004
    N.J.
    That's a nursery spade.
    This is a trench or drain spade.
    http://cdn3.volusion.com/oh2c3.ohvt5...tos/DSSS-2.gif
  10. #4570
    Oct 2013
    USA MD 21030
    It works OK as it is, so I see no need to braze or weld it. And I have a feeling that the heat from such a repair may damage the wood, which I think is curved so it extends close to where the crack is. It may be a "nursery spade", but I find it has the right size and shape for digging trenches for laying 8x16 concrete blocks, and it also works well for scooping small size rubble and gravel.
    I have had many implements fail due to wood handles breaking. This has most recently happened with a cutter mattocks
    And a couple of rakes:
    I also have a shovel with a broken handle. Many of these tools had been left outside, and were damaged due to rain and insects. Now I have my woodshed rearranged and organized so I can keep them in there.
