Results 1 to 8 of 8
Thread: Can I get Morse Taper adapters apart?
    Default Can I get Morse Taper adapters apart?
    I use a tailstock drill with a MT2 adapter (J33 on chuck end, MT2 on tailstock end).
    If I add a MT3 - MT2 adapter to use it on a MT3 spindle, will I be able to remove this adapter easily or is it going to be a nightmare?
    Suggestions, if there are any, to ease the removal.
    Taylorsville Ky
    The adapters have a slot at the small end that you put the correct size wedge in and smack it with a hammer to separate them. You can buy the wedges and adapters from Enco.
    May 2008
    Eastern Nebraska
    The MT adapters should have knock out slots so you can use a wedge if you need to separate them.
    Edit: not quick enough with my typing
    regards
    3t
    Buffalo NY
    If the 2 to 3 mt adapter has a tang slot, removal is easy.
    If it has no tang slot, and is more like a tapered bushing,
    I have used a pair of crescent wrenches creatively to get
    them apart.
    --Doozer
    Feb 2008
    Ashcroft, British Columbia
    If the adapter does not have a tang slot you can slot a tapered fallers wedge and drive it between the back of the chuck and the adapter. works every time.
    Ernie (VE7ERN)
    Apr 2009
    Quote Originally Posted by Dunc
    If your spindle is hollow, a lathe spindle for example, you will be able to knock the adapters out easily enough by poking a broomstick or some such in behind and giving a tap.
    If you have the adapters out but the MT3 is stuck on the MT2 all you need to do is put a bar in hole in the end of the MT3 adapter and giving it a tap, or maybe knocking the ensemble of bar and adapters on a solid surface.
    Jun 2008
    NSW Australia
    If you have a slot in it , you can use one of these. They work great and you only need one hand to use it.
    http://cgi.ebay.com.au/SEMI-AUTOMATI...item5190e66f82
    Davo
    Nov 1999
    SE OZ
