Greetings,
I have a couple of gear leg weldments that were misdrilled at the factory, i.e, off center,...about 50 holes worth total. Most are 3/16, some are quarter inch. If I try to repair the weldments which I believe are 4130N and maybe thicknesses of .063 or .100, can I get some one to TIG weld the holes undersize so that I can then drill them back up in proper orientation.
I will need to match drill them to a laminated aluminum spar which is approximately an inch thick. I have a number of brass bushings which can protect the aluminum as I drill them back up to a final reaming size.
My fear is that the welded area will be extremely hard to drill through and difficult to ream, as well as not being as structurally sound.
Am I better off just shelling out 5 or 6 hundred dollars to buy new weldments?
I have a Miller 175 Mig but I don't have the consistent skills to weld something like this.
Thanks.
Dave A.
You don't think Boeing, and Northrop Grumman, Cessna, Piper, Airbus and the rest of them don't repair parts???? You better never fly again, the plane is destined to fall out of the sky.
