Results 1 to 5 of 5
Thread: Wrist pin bushing
    Lexington, Ohio
    Default Wrist pin bushing
    Have searched but have not found anything for what appears to be an off the shelf bushing for an air compressor wrist pin.
    There are numbers on it 9A FM-X/5B and on the bottom 24602 perhaps 24803.
    Dim OD likely .8265
    Wrist pin OD is .708
    OAL .9
    Does anyone know if these number correlate to industry standards that could be looked up?
    Thanks
    Deep in the Heart of Texas!
    .8267 is 21mm.
    .7086 is 18mm.
    .9055 is 23mm.
    Look for a metric bushing.
    Lexington, Ohio
    Just may be!
    Thanks
    Quote Originally Posted by Ken_Shea
    Ken,
    The "FM" tells me it is most likely a Federal Mogul bushing. I have a pretty good interchange at the shop and also several listings by size. If you shoot me an e-mail reminder Monday morning I should be able to find something.
    FYI .. most piston pin bushings are designed to be finish honed to size. ANy good automotive machine shop with a Sunnen connecting rod (horizontal) hone should be able to do the job.
    Bill Koustenis
    Advanced Automotive Machine
    Waldorf Md
    www.enginerepairshop.com
    Lexington, Ohio
    Will do Bill, thank you.
