Results 1 to 10 of 12
Thread: Noobish question: Best way to find the center of bar stock
    Nov 2004
    Tipp City, Ohio
    Default Noobish question: Best way to find the center of bar stock
    And I mean the ends...
    I Googled it, seen all kinds of methods..Just looking for a simple tool or method that is idiot friendly and doesnt require a lathe..
    Most people would use a centre finder such as this... http://www.rhrtools.co.uk/shop/image..._finder1_c.jpg
    Which reminds me, I must buy one.
    Chris.
    Oroville, WA
    Western New York U.$.A
    This is as good away as any.
    I use the thing on the left of this next picture. You make an X using the center find attachment and where the lines cross is the center. Do this line with a sharp scribe and your center punch can be felt to fall into the groove made by the scribe.
    Nov 2004
    Tipp City, Ohio
    Yes, that little one looks about perfect... now where to buy?
    Aug 2003
    Default Center Head
    Check with almost any old machinist as they will have one or two extra heads in their collection and very seldom used. All it takes is to find a blade that fits.
    JRW
    Apr 2009
    None of those instruments will find the centre unless they are accurate. If in doubt scribe three lines with the tool at about 120 degree angles. If they all cross at the same point the device is accurate, if you get a small triangle scribed the centre is in the middle of the triangle.
    Even though the instrument may be accurate the end result depends on skill with the scriber.
    Toledo, Ohio
    Get thee a height gage with scriber or hermaphrodite caliper and learn their many uses. Finding center of round, square, rectangular ao hex stock is but one.
    The older shop texts, How To Run a Lathe, the Atlas Lathe book, and older Starrett catalogs demonstrate uses of the various tools.
    Dec 2008
    jefferson,georgia
    Default how exact?
    I'll probably take some grief for this,but how exact a center (or centre) are you hunting? I've learned (alot of it from this forum) that an exact center for a fabricator and a center for a watchmaker are to VERY different points.The instruments shown in the other posts are more than accurate enough for the fab stuff I do,even taking into consideration failing eyesight. However,they may not produce the results needed for someone re-manning a a turbo,so I guess its a question of of thousandths or tens?
    Jul 2001
    Green Bay, WI
    The simplest tool is a center punch that comes out of a funnel.
    You stick the concave funnel shape onto the end of a round shaft and hit the punch, and its done. I don't have a photo to show you
    When not using the Lathe for such an assignment, and location is not super critical, I lay the round down on the workbench and place a tool bit about half the diameter on the bench at the end of the shaft.
    roll the round back and forth, and using a felt tip maker on top of the tool bit, I draw a series of horizontal lines OR if the felt tip is large, just hold it near the center of the round.
    The felt tip will actually be slightly above C/L
    When you remove the round , you have a nice shiney spot exactly in the middle of the round. This can be a very accurate measure, when you use a spring punch on the shinney part before center punching
    Rich
