Originally Posted by
knots43
I own an old import vertical mill which has close to .025 backlash in both the x and y axis. It was even more until after I worked the lead nut mountings over.
I don't use the mill except for my own needs fabricating jigs and such. But I feel the need to repair this machine to reduce the backlash and improve its performance .
My plan is to purchase a clyndrical ACME nut from a supplier , such as Roton Products, and fabricate a holding fixture to hold the nut. This assembly would then replace original nut.
I have checked the original acme feed screw which appears to be in good condition, and as far as I can tell true to acme screw tolerance. I suspect that the nuts were originally machined out of tolerance.
Have any of you repaired your mill using this method ? Comments ?
