In working on this T&CG, I'd like to remove a bit of vibration in the motor. Static balance isn't going to fix it; to much drag from the bearings and parts of the shaft are several thou out so static balance on anything but the bearings would seem to introduce error; besides i don't have a static balance with rails just the right distance apart to rest it right where the bearings would be.
The proper way to do this, and any spindle or rotor is dynamic balancing; for the unfamilair that is measuring how much the element is out while running at speed, adding or removing weight in the right spot and trying again....but i can't recall there being content on dynamic balancing in the home shop?
Any balancing experts here that can describe the process, or how it might be simplified for the home shop? I guess you need some sort actuator to measure the vibratory movement and way to monitor the shaft speed or angle?...and a V block bed for the bearings to sit in? I know high end commercial balancers can do everything but turn the lights out...but is there a doable way to simplify the things to the get worst of the imbalance out?
Anyone accomplished this at home or have ideas how to go about it?
thanks
crap, another title typo, can someone add the "h" in home? thanks![]()
i'd seen it done, magic marker lines on the part and strobe light for small DC motors in china (he was the highest paid worker in the plant) but never clued in that its the accelerometer that fires the strobe! thank you. to get my feet wet i was thinking narrow project scope so i like this.
its a low frequency unit so should work just fine....that was bargooon of opportunity, first i need to get the basics lined up
