Results 1 to 10 of 14
Thread: I want to build small milling vise, as seen...
    Jan 2009
    Default I want to build small milling vise, as seen...
    I like this style of vice in this video:
    http://www.youtube.com/user/tryally#p/u/3/RixYKIZqJnY
    Anyone here have any other designs? I've watched all his videos and it seems easy to make, just wondering if there are any others out there that have them.
    Champaign-Urbana, Illinois
    Neat little low profile vise. Looks pretty simple. The C shaped frame that makes up the body of the vise and the fixed jaw is just bolted down to one T-slot. The movable jaw is snugged down with the two bolts in the other T-slot to keep it from lifting and then tightened from the right side with that triangular shaped piece. Then the two bolts on the movable jaw are tightened the rest of the way. That should be pretty easy to make.
    Stuart de Haro
    Jan 2009
    Do you think aluminum will suffice? I am making one for my sherline lathe, with a milling column (part 3050) attachment. I'm not making big parts by any means, mainly stuff for small model cars.
    Jun 2007
    Norway
    Thomas
    Problems worthy of attack prove their worth by hitting back
    - Piet Hein
    Canada, Bc
    Aluminum will likey suffice yes, but steel is much more rigid.. but is more likey to marr parts.
    Aluminum jaws on a steel body are typicaly great.
    (Note all steels are nearly the same rigidity, so just use whatever steel you like to machine/can easily get/etc)
    Jan 2009
    So here's a design based on the youtube version. I have other pics with all the dimensions, this just shows the table, and all the parts of the vice.
    Lexington, Ohio
    That is a great little vice, he was thinking out of the box on it.
    I would think careful milling of steps in the bottom to match the T-slots would be a nice addition to save a couple squaring setups. Also like the idea of steel, though aluminum would work out very well and if you wear it out, just make another.
    Independent principality of Sinquefieldia (formerly Missouri in the USA)
    It seems to be the basic "table-as-part-of-vise" vise...... With steps milled in to hold parts.
    The back side may or may not be that useful, as it is not clamped against in the way he is using it.
    You could use the typical shaper hold-downs for even thinner total height.
    You can make the vise with less material, and add separate jaws so ANY type or shape can be held well.
    I made one a while back , which was shown in an HSM article. It has the same elements, but has replaceable jaws, which can have any sort of steps in them. I used steel, you wouldn't have to.
    particular shape and double screw are due to single slot...... but it has worked out well.
    Surrey BC Canada
    The small Sherline vice is nice. The website that goes with it is interesting.
    JT. That's a nice little vice. Which issue was the write up in? I have a PM horizontal making its way to me and its viceless. :-)
    Thanks
    Dave
    Jan 2009
    Quote Originally Posted by Ken_Shea
    How would it be tightened to the bed if the slots were part of the vise?
