Results 1 to 10 of 36
Thread: Good Auto Darkening Welding Helmet
    Mar 2010
    Elizabeth City, NC
    Default Good Auto Darkening Welding Helmet
    Does anyone have an opinion on the subject? I have a cheap Blackstone model and I find myself struggling to see the weld puddle at the lightest setting (9). Its a few years old. Thought I would try this model OPTREL K6803 ( E680 ). Thoughts??
    Thanks,
    HAP
    Canada, Bc
    HAP: what current and process are you welding with?
    What consumable are you using?
    Have you tryed wipeing off the front of the lense? it often gets covered in smoke, especialy with flux core mig welding.
    airsmith282 Guest
    i like my lincoln 100% solar ,but i adore my miller elite
    Jul 2005
    N W La.
    I have the same - or similar - problem... but I have pretty well determined that my 70 yr old eyeballs are the culprit. I have 3 friends in the same general age group and they are also having a similar problem -- one told me recently he had gotten to where he wouldnt even attempt to weld anymore because he just made a mess After my last few attempts, I may have to give it up also.
    This getting old SUCKS
    Jul 2007
    So. Cal.
    I have had my Optrel for over 7 years now and it has worked great. Had to buy a new one about 3 years ago when my old one dropped several stories and broke. Other than that no problems. There are a few other members here that also use the Optrel and will reccomend them.
    Dec 2008
    The Four Flags City
    My main and favorite helmet is a Huntsman 951P with an 1100IVXL lens.I recently aquired a Miller Elite and like it a lot.
    What ever helmet you get make sure you can get replacment lenses easily.
    Feb 2008
    Arkansas
    If you are wire welding, try shining a quartz light onto the area you are welding. That will help those 70 year old peepers quite a bit to see the weld. Mine aren't but 60 but it sure is hard to see the weld joint thru an autodarkening hood without the extra light. JMHO
    Patrick
    Taylorsville Ky
    After years of using a standard lens hood I bought a HF auto dark hood and I like it. I don't weld enough to pay for an expensive one.
    I have found that a spot light on the work where I am welding does wonders for seeing what I am doing. Normal shop lighting is not enough for anyone, young or old.
    Oct 2006
    Mohegan Lake, NY
    I have a Speedglas that's been great for the couple of years I've had it...Provided I don't forget to turn it on. :blackeye:
    Jul 2005
    N W La.
    I have tried this extra light with my HF hood (not with Quartz) and have a problem with the added light making the hood darken prematurely. Either of you had that problem - do you position the added light over your shoulder or something - or (probably the case!) is my hood just too sensitive? I am gas wire welding...
    I have tried 2-3 other hoods and still had problems following the bead, though not with extra light...
