Well.. It is stuck.. Mentally and physically. I am building a pontiac Quad4 motorcycle, Did the sketches, got the springer front end, Got the 6 speed harley transmission, Wheels, Now the 90 degree drive has me still stumped. (motor is inline, transmission is 90 degrees)
We used a boat foot on the pinto powered 3 wheeler. Can't find one I can afford.
Possibly, two pinon gears from a rear axle? the gears would have to be 45 degree. unit needs to be as small as possible, engineering the drive it needs to at least transfer 60hp. Rear drive belt specs, not mine.
HELP... Without a solution, I will have to build another Boring harley clone with the parts I have already. (been there done that)
I'll post a sketch if you can't see what I am doing..
[This message has been edited by ibewgypsie (edited 09-22-2003).]
