Results 1 to 10 of 12
Thread: Sleeving a cylinder rod (pics)
    On the Oil Coast
    Default Sleeving a cylinder rod (pics)
    We have this old W.A.Whitney angle iron shear at work,good machine,old parts now obsolete.It consists of a frame that holds a set of blades and a cylinder that holds a knife.It works on the same principal as a quillotine.
    It had sat in storage for years before we got it and the cylinder rod had developed some rust pits,but the rod side of the piston is low pressure since it only retracts the knife.We have used it for years,but the rod seals finally went out and it started puking oil.Quick call to the MFG found no parts,not even seals.
    Normally I would simply order up a section of chrome rod and machine a new one.This one I couldn't,the end of the rod that holds the knife on is hardened and larger than the rod diameter.Grinding and re-chroming was out as well since I was quoted $550 and six weeks lead time.
    My solution was to buy a section of chromed OD tubing and make a sleeve.Tube is 3.00" OD and 2.460 ID.Of course they didn't put a center in the end of the rod,so that was the first operation.
    Centered up and the sleeve material-
    On the Oil Coast
    The rod was machined to 2.460 and given a .001" taper over it's length with a mic and a few passes of emery paper.Once that was finished it was removed from the lathe,coated with Loctite 271 and slipped together on the arbor press.
    The turned rod -
    Once in place the sleeve was faced .001-.0015" proud of the rod end so the piston would bear up on the sleeve.
    Now all that's left is to pack the piston and gland,then re-install.
    May 2010
    Neat trick! Thanks for posting!
    Allen Hunt
    Dec 2003
    Nice work as usual D!!!
    I likey that trick of using and .001 taper!!!
    Never woulda thunk that myself.
    Taylorsville Ky
    Why the taper on the pin and what was the fit of sleeve to the pin? I have a guess about why.
    On the Oil Coast
    Quote Originally Posted by Allen Hunt
    Allen Hunt
    Your welcome and welcome to the forum Allen!
    Carl,I wanted the sleeve to just slip on so it would land about half the way home before it met any resistance.Luckily the tube ID measured within .0002" of round at each end.With the 271 in there I had to be quick,I just barely got it pushed home before it grabbed.
    Taylorsville Ky
    I figured that was what you were going for. Nice job.
    NL
    Great Job
    eddie
    please visit my webpage:
    http://motorworks88.webs.com/
    with the taper strategy, any resulting OD difference between the two ends of the sleeve....I mean half is a press fit and half not?? ....or was the whole thing turned afterward
    On the Oil Coast
    Quote Originally Posted by Mcgyver
    I get 3.0002 on the tight end and 2.999 on the small end,so not to bad,the rod gland bore is 3.005" so we're good.
    Couldn't turn the OD though,it's chromed.
