Results 1 to 10 of 13
Thread: Whew up and running
    Jun 2010
    NC
    Default Whew up and running
    I finally got the machine out of the car and into the house but just barely, it's one heavy son of a gun. I didn't feel comfortable taking the headstock off the ways I was worried about realigning it as I didn't see any alignment pins. Here is a shot of the ways and headstock before I put it on the pallet to winch it up the stairs.
    I got the bench built using 2x4's and 3/4 plywood it's short as I'm limited on headroom. Lathe reassembled and on its new home.
    Boards on the sides will and back will be my chip collecter so hopefully I won't be tracking metal bits all around the house. I figure my shop vac should be able to handle debris. Now I need to find/make a small collector for the precious metal I plan to turn I don't want to mix metals.
    I turned the motor on before placing the belts and it was smooth as silk but after putting the belts on its louder than I expected I have it running on the slowest speed at the moment. The manual doesn't give any instructions on the belts so I put them on as I thought correct. Do my belts look ok or have I screwed something up?
    The lathe seemed to be running ok so I found a piece of threaded rod chucked it up and ground a HHS bit, looked so bad I almost couldn't bring myself to use it but it worked fine and I cut down the end of the rod.
    northwest wisconsin
    i idler pulley should be on the other side of the belt i think.
    i have some scrap s.s. rounds and crap steel rounds that are good to play with. they are about 10 inches long and about 3/4" dia. even some grade 8 bolts that would fit in the flat rate box.
    i'd be happy to mail them usps flat rate if you'd send the postage to me when you get the stuff. . . . i didn't notice where you are, maybe its impossible.
    davidh
    Jun 2010
    NC
    Your right David I had it on the wrong side thanks. I'll send you a pm on the scrap I really appreciate the offer. Have a good one.
    Jim Doherty
    Jun 2002
    You're gonna have a LOT of fun with this little machine! Good luck and best wishes!!
    Al
    Albuquerque
    Do I see a chuck key sitting in the chuck? Tich Tich!
    ...lew...
    Jul 2007
    No Cal.
    Quote Originally Posted by Lew Hartswick
    ...lew...
    5 second rule
    Aug 2008
    Missouri, USA
    Ummmm -- What they are saying is......
    Jun 2010
    NC
    oops my bad need to get a spring for it so it can't rest in the chuck. Thanks for the reminders I don't need a trip to the emergency room.
    Thanks, Jim Doherty
    northwest wisconsin
    i drilled a hole in my table just next to the base of the lathe head stock and close to the end of the ways so i can just drop one side of the chuck HANDLE in it. i never hardly fail to place the key in it, or if im doing short repeat jobs, i just hold it the key in my left hand continuously. i suppose thats a no no also but i guess its whatever works for whoever... ...i am kinda decent at multi-tasking.
    On the Oil Coast
    Quote Originally Posted by Jim Doherty
    Thanks, Jim Doherty
    I hate saftey keys,one shop I worked in had one so tough on a lathe if you slipped and let go it would pop out and clock you in the head
    Good going on the move,for little machines they sure are heavy.When I brought my X-2 mill home I said to myself,ahh 140lbs I can handle it.After 100 feet or so to the door,up six stairs into the house and finally on the workbench I decided the next time it moved would be on a hand truck
