Results 1 to 10 of 23
Thread: Forge design ? OT
    Jul 2005
    Burnet, TX
    Default Forge design ? OT
    Long ago I took metal shop in the 9th grade. First project was to make a chisel. The furnace that we used for forging and heat treating was a natural gas fired and was about one cu-ft in size. There were 3 burners on 2 opposite sides facing one another. Here is a comercially avaliable 3 burner Propane forge.
    Anybody know why the burners are vertical?
    Byron Boucher
    Burnet, TX
    oldbikerdude37 Guest
    Just a guess but maybe the heat would shoot down, rise and you could use it twice.
    The olny time I used a deal like that was for branding cattle, you just wanted a good even heat. Our thing was a crude steel pipe with some pipes.
    It will be interesting to see answers from people who know why they do that.
    Jun 2006
    Austin, Texas
    I took a bunch of pictures of a neat benchtop forge that my Blacksmithing instructor makes for friends (but won't sell, due to liability reasons). I uploaded them to my photobucket, but let me ask Will if I can post them here.
    His venturi is horizontal, but enters at the same point.
    The one in my Photobucket is a made from a piece of 6x6 Schedule 40 square tubing. The back is open with a set of bricks to close-off as much as you need, while still allowing for heating any ~5" section of a long iron.
    Jun 2005
    Almost Dallas
    My wild guess is that having the burners vertical keeps the forge balanced...not likely to tip over onto the side as it would be if the weight of the burners was off to one side. Another plus is that you're less likely to set your beer down on top of the forge and ruin it.
    The beer, that is.
    Sep 2009
    Sacramento, CA
    Probably just to save bench space.
    Apr 2009
    Columbus Texas
    I would have to say to save space. And to heat a flat bar more evenly ( bigger target). The flat bar will more than likely be laying flat so the flame will hit the broad side and not the narrow side. But since heat rises and that includes spent air ( no oxygen). The burners might suck up the spent air and not want to burn efficiently. Cold air from the side would be much better.
    I agree that the burners are vertical to save spave. I would not have this forge for the work I do personally. There is going to be a hot spot right under the burners. Burners should not point directly onto the work but should come in to create a vortex or swirling fire. Just my humble opinion but I use a forge about five days a week and have made all my own.
    Plain ol Bill
    Oct 2004
    Northeast Oh-hi-Owe
    Quote Originally Posted by Plain ol Bill
    Hi Bill... Ya got a camera? Hint...hint.
    Western New York U.$.A
    I wonder what kind of bricks are in this particular oven. The kind sold at Tractor Service Supply which are kind of heavy and very hard or the light bricks that are also a bit fragile in that you can scrape channels into them for heating wire?
    The particular brick that TSC sells is the same as used in my wood burning stove for the house, that is, heavy and durable. Wonder if they would work for a heat treat oven?
    Sep 2004
    Edison Washington
    Cheap or good- pick one.
    most relatively cheap commercial forges use vertical burners, cause its cheap and easy to build em that way.
    this is a great book about forge design-
    http://www.amazon.com/Gas-Burners-Fo.../dp/1879535203
    and this is a great source of info-
    Ron has designed a simple forge that hundreds, probably thousands, of smiths have built variations on.
    http://ronreil.abana.org/Forge1.shtml
    this guy sells premade burners-
    http://www.hybridburners.com/
    Chile make some nice little forges that use a round shape, with an offset burner, to induce a swirling pattern of heat.
    http://www.chileforge.com/
    I make my own forges, using castable refractory from Pryor Giggey- much better than bricks from Tractor Supply.
    http://www.pryorgiggey.com/
    I cast cylinders, using two pieces of sonotube for a mold.
    Its a design a friend of mine worked out, you can make em any size or shape that way.
    Castable refractory will last a long long time- and its the radiant heat from the heated up refractory, as much as if not more than, the direct heat from the flame, that makes a forge work.
    Just came in, all hot and sweaty, from the forge ten minutes ago, after forging tapers and textures on about 50 pieces of stainless steel.
