Results 1 to 4 of 4
Thread: Trunnion on a indexing spacer?
    Sanger, Texas
    Default Trunnion on a indexing spacer?
    I'm trying to figure out fixturing on some cylindrical parts. They need machining operations performed on the face and then need to be turned 90 degrees and a precise hole bored perpendicular. I'm picturing a clamping block holding four parts, secured to a trunnion, secured to a indexing spacer in the vertical position with a tailstock at the other end. This is for small production runs on a VMC with an APC. I cannot afford to buy a 4th axis trunnion setup but I have a super spacer. Has anyone done this or seen it done? Is this a crazy idea? The risers on the right are the ones I'm trying to work out.
    Bob
    Nottingham, England
    Part mounted onto angle plate held in 4th axis
    Do top face operation
    Index 90 degrees and offset to do side hole operation.
    Sanger, Texas
    Quote Originally Posted by John Stevenson
    Yup, thought about that. Not enough real estate. I'd like to get at least four pieces in the machine at a time. That would mean they need to be mounted in line. Hence the trunnion idea. I would probably use a pair of angle plates to attach the trunnion table to. I really would rather find an off-the-shelf solution but, my budget is pretty limited.
    Bob
    Nottingham, England
    Long angle plate mounted in 4th axis with end of angle plate supported on 4th axis tailstock.
    Mount 4 pieces etc.
    Or even use a piece of square with one end turned round to fit 4th axis chuck and other end centred, mount to top of square.
