OSHA Releases Final Rules for Acetylene Storage Requirements
The revised OSHA standard for acetylene took effect.
The important or interesting part was the revision of the flow rates.
Originally Posted by
OSHA
Although the new revision only advises against transporting in automobiles, it specifically prohibits storing acetylene cylinders in confined spaces, such as unventilated cabinets, closets, and drawers.
* While the old standard recommended a flow rate of 1/7 of the cylinder capacity regardless of the duration of use, the revision has advises a flow rate of 1/10 per hour for intermittent use and 1/15 for continuous use.
They have a pdf down load with all the details.
E federal register notice.
OSHA observer Finials rules for Acetylene Nov 2009
And for all the old farts, that were taught, to crack the valve to blow out all the contamination out of the connection. That is now a NO,NO!
OSHA
* It is recommended that acetylene cylinders valves are not opened without a regulator and flow restrictor.
* The new standard also suggests that the CGA connection is visually examined for signs of contamination and, that all contamination is removed before it is connected to the regulator.
7 pages of verbage but its only our tax dollars @ work
Glen
